Logitech M100 USB Cable Replacement
  1. Logitech M100 USB Cable Replacement, USB Cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech M100 USB Cable Replacement, USB Cable: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Not all variants of this mouse require the mouse feet to be taken off for disassembly, but their removal is detailed anyway.
    • Carefully remove the feet of the mouse with an opening pick.
    • Keep track of the mouse feet, as you'll be reapplying them at the end of the guide.
  2. Logitech M100 USB Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech M100 USB Cable Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the 10mm screws on the bottom of the mouse.
    • Once all screws are removed, use the plastic opening tool to gently pry the mouse apart. This shouldn't take much force.
  3. Logitech M100 USB Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech M100 USB Cable Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the mouse is opened, locate the USB cable's 5-pin connector, which is plugged directly into the mouse's mainboard.
    • Take note of the position and route that the USB cable takes before removal. The replacement cable must follow the same route when inserted.
    • Using a plastic opening tool, gently remove the 5-pin connector from the mainboard.
    Interessante mas muito básico.
    Interessante seria se explicasse o significado das cores
    Cabo Verde(Green) -
    Cabo Branco(White) -
    Cabo Vermelho(Red) - (Julgo ser 5v+)
    Cabo Preto Fino(thin Back) - (Julgo ser terra (GND)
    Cabo Preto Grosso(thick Back) - (Julgo ser massa Chassi)
    É bem mais interessante aprender e saber do que ir comprar já feito.
    Mais a mais, temos por vezes a necessidade de o rato tenha cabo curto e não longo (encurtar o cabo)
    CarlosAulasEVT@gmail
    Carlos Sousa - crwdns2934203:0crwdne2934203:0
  4. Logitech M100 USB Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech M100 USB Cable Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the replacement USB cable and connect it to the mainboard.
  5. Logitech M100 USB Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech M100 USB Cable Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Ensure that the 5-pin connector is fully seated into its slot on the mainboard. You may want to use a spudger to apply pressure onto it.
    • Using a plastic opening tool, route the cable through the case in the same way that was noted in Step 3.
  6. Logitech M100 USB Cable Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After re-assembling the mouse, don't forget to reattach the mouse feet onto their correct locations on the bottom of the mouse.
To reassemble, follow the steps in reverse order.
Jake Janicke
crwdns2935283:010/26/17crwdne2935283:0
161 crwdns2915208:0crwdne2915208:0
DePaul University, Team S1-G5, Dush Fall 2017 crwdns2935289:0DePaul University, Team S1-G5, Dush Fall 2017crwdne2935289:0
DPU-DUSH-F17S1G5
Removing the mouse feet is completely unnecessary, as there are no screws underneath the feet.
Andy Joonseo Bae - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 5,820
