Logitech K480 Rubber Dome Sheet Replacement
  1. Logitech K480 Rubber Dome Sheet Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the keyboard over.
  2. Logitech K480 Rubber Dome Sheet Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K480 Rubber Dome Sheet Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K480 Rubber Dome Sheet Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four rubber feet with a spudger.
  3. Logitech K480 Rubber Dome Sheet Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K480 Rubber Dome Sheet Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K480 Rubber Dome Sheet Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide open battery panel.
    • Remove the batteries.
  4. Logitech K480 Rubber Dome Sheet Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K480 Rubber Dome Sheet Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 4 mm screws under the rubber feet using a Phillips #0 screwdriver.
  5. Logitech K480 Rubber Dome Sheet Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K480 Rubber Dome Sheet Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4 mm screws from beneath the battery cover using a Phillips #0 screwdriver.
  6. Logitech K480 Rubber Dome Sheet Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K480 Rubber Dome Sheet Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K480 Rubber Dome Sheet Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting by the dial, slide the spudger between the front and back panels until it lifts and snaps.
    • Slide a blue pick in to keep the pieces apart while you work on other areas.
    • Continue prying along the edges until you have enough opened that you can pull both pieces apart gently with your hands.
    • The loud snaps are the clips that hold the pieces together. They're not breaking and you do not need to be alarmed.
  7. Logitech K480 Rubber Dome Sheet Replacement, Metal Plate: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K480 Rubber Dome Sheet Replacement, Metal Plate: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K480 Rubber Dome Sheet Replacement, Metal Plate: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the eight 3 mm screws using a Phillips #00 screwdriver
    • Remove the five 2 mm silver screws from the metal plate using a Phillips #00 screwdriver.
    • Remove the single 4 mm black screw by the motherboard using a Phillips #00 screwdriver.
  8. Logitech K480 Rubber Dome Sheet Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K480 Rubber Dome Sheet Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up and remove the metal plate.
  9. Logitech K480 Rubber Dome Sheet Replacement, Rubber Dome Sheet: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two black 4 mm screws from the Bluetooth motherboard with a Phillips #00 screwdriver.
  10. Logitech K480 Rubber Dome Sheet Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the flex circuit and move it aside.
  11. Logitech K480 Rubber Dome Sheet Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the rubber dome sheet and remove it.
Marie Sewell
crwdns2935283:009/04/24crwdne2935283:0
309 crwdns2915208:0crwdne2915208:0
Utah Tech University, Team 1-8, Crenshaw Fall 2024 crwdns2935289:0Utah Tech University, Team 1-8, Crenshaw Fall 2024crwdne2935289:0
UTAHTECH-CRENSHAW-F24S1G8
crwdns2942667:0crwdne2942667:0 310
