Logitech K480 Flex Circuit Replacement
  1. Logitech K480 Flex Circuit Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the keyboard over.
  2. Logitech K480 Flex Circuit Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K480 Flex Circuit Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K480 Flex Circuit Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four rubber feet with a spudger.
  3. Logitech K480 Flex Circuit Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K480 Flex Circuit Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K480 Flex Circuit Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide open battery panel.
    • Remove the batteries.
  4. Logitech K480 Flex Circuit Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K480 Flex Circuit Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 4 mm screws under the rubber feet using a Phillips #0 screwdriver.
  5. Logitech K480 Flex Circuit Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K480 Flex Circuit Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4 mm screws from beneath the battery cover using a Phillips #0 screwdriver.
  6. Logitech K480 Flex Circuit Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K480 Flex Circuit Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K480 Flex Circuit Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting by the dial, slide the spudger between the front and back panels until it lifts and snaps.
    • Slide a blue pick in to keep the pieces apart while you work on other areas.
    • Continue prying along the edges until you have enough opened that you can pull both pieces apart gently with your hands.
    • The loud snaps are the clips that hold the pieces together. They're not breaking and you do not need to be alarmed.
  7. Logitech K480 Flex Circuit Replacement, Metal Plate: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K480 Flex Circuit Replacement, Metal Plate: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K480 Flex Circuit Replacement, Metal Plate: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the eight 3 mm screws using a Phillips #00 screwdriver
    • Remove the five 2 mm silver screws from the metal plate using a Phillips #00 screwdriver.
    • Remove the single 4 mm black screw by the motherboard using a Phillips #00 screwdriver.
  8. Logitech K480 Flex Circuit Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K480 Flex Circuit Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up and remove the metal plate.
  9. Logitech K480 Flex Circuit Replacement, Flex Circuit: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K480 Flex Circuit Replacement, Flex Circuit: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two black 4 mm screws from the motherboard with a Phillips #00 screwdriver.
  10. Logitech K480 Flex Circuit Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K480 Flex Circuit Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the flex circuit from the back of the motherboard.
    • The flex circuit is fragile so be gentle when pulling it out.
  11. Logitech K480 Flex Circuit Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K480 Flex Circuit Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two black 4 mm screws from the dial motherboard below the regular motherboard with a Phillips #00 screwdriver.
  12. Logitech K480 Flex Circuit Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the circuit sheet from behind the dial motherboard.
  13. Logitech K480 Flex Circuit Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two black 4 mm screws holding the Bluetooth component on the left side using a Phillips #00 screwdriver.
  14. Logitech K480 Flex Circuit Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the flex circuit and remove.
Madison
crwdns2935283:009/04/24crwdne2935283:0
655 crwdns2915208:0crwdne2915208:0
Utah Tech University, Team 1-8, Crenshaw Fall 2024 crwdns2935289:0Utah Tech University, Team 1-8, Crenshaw Fall 2024crwdne2935289:0
UTAHTECH-CRENSHAW-F24S1G8
crwdns2942667:0crwdne2942667:0 140
