Logitech K480 Easy-Switch Dial Replacement
  1. Logitech K480 Easy-Switch Dial Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the keyboard over.
  2. Logitech K480 Easy-Switch Dial Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K480 Easy-Switch Dial Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K480 Easy-Switch Dial Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four rubber feet with a spudger.
  3. Logitech K480 Easy-Switch Dial Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K480 Easy-Switch Dial Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K480 Easy-Switch Dial Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide open battery panel.
    • Remove the batteries.
  4. Logitech K480 Easy-Switch Dial Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K480 Easy-Switch Dial Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 4 mm screws under the rubber feet using a Phillips #0 screwdriver.
  5. Logitech K480 Easy-Switch Dial Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K480 Easy-Switch Dial Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4 mm screws from beneath the battery cover using a Phillips #0 screwdriver.
  6. Logitech K480 Easy-Switch Dial Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K480 Easy-Switch Dial Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K480 Easy-Switch Dial Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting by the dial, slide the spudger between the front and back panels until it lifts and snaps.
    • Slide a blue pick in to keep the pieces apart while you work on other areas.
    • Continue prying along the edges until you have enough opened that you can pull both pieces apart gently with your hands.
    • The loud snaps are the clips that hold the pieces together. They're not breaking and you do not need to be alarmed.
  7. Logitech K480 Easy-Switch Dial Replacement, Metal Plate: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K480 Easy-Switch Dial Replacement, Metal Plate: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K480 Easy-Switch Dial Replacement, Metal Plate: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the eight 3 mm screws using a Phillips #00 screwdriver
    • Remove the five 2 mm silver screws from the metal plate using a Phillips #00 screwdriver.
    • Remove the single 4 mm black screw by the motherboard using a Phillips #00 screwdriver.
  8. Logitech K480 Easy-Switch Dial Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K480 Easy-Switch Dial Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up and remove the metal plate.
  9. Logitech K480 Easy-Switch Dial Replacement, Easy-Switch Dial: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two black 4 mm screws from the dial motherboard located on the upper right corner of the device with the Phillips #00 screwdriver.
  10. Logitech K480 Easy-Switch Dial Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K480 Easy-Switch Dial Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the Easy-Switch motherboard up to pop it out from the dial.
  11. Logitech K480 Easy-Switch Dial Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K480 Easy-Switch Dial Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K480 Easy-Switch Dial Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pop out the Easy-Switch dial by gently pressing your finger on the underside of of the dial.
Marie Sewell
crwdns2935283:009/04/24crwdne2935283:0
309 crwdns2915208:0crwdne2915208:0
Utah Tech University, Team 1-8, Crenshaw Fall 2024 crwdns2935289:0Utah Tech University, Team 1-8, Crenshaw Fall 2024crwdne2935289:0
UTAHTECH-CRENSHAW-F24S1G8
Very good tutorial, it's a shame we don't know where to get the Logitech K480 Easy-Switch Dial part. Sincerely.
Herve SPADACINI - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 346
