Logitech K360 Cleaning and Key Replacement
  1. Logitech K360 Cleaning and Key Replacement, Cleaning and Key: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K360 Cleaning and Key Replacement, Cleaning and Key: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K360 Cleaning and Key Replacement, Cleaning and Key: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the keyboard face down, so that the keys are not visible. On this side, a detachable battery compartment cover will be visible. Once identified, ensure that the batteries are removed from the keyboard to ensure safety for yourself.
    • The keyboard should be disconnected, powered off, or have batteries removed before any technical work is done on the device!
  2. Logitech K360 Cleaning and Key Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K360 Cleaning and Key Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K360 Cleaning and Key Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the key that needs replacing.
    • Multiple thin tools can be used to pick out the key from the keyboard. In this instance, a 2mm precision flathead screwdriver was used.
    • Insert the flathead screwdriver at an angle underneath the key and begin to pry the key up with the desired tool. Pry from different angles/corners till the key pops off. Doing this will expose the underside of the keyboard.
  3. Logitech K360 Cleaning and Key Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K360 Cleaning and Key Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K360 Cleaning and Key Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To properly clean the keys, soapy water will be made by using one cup of water, one tablespoon of baking soda, and one tablespoon of soap. Add together in a desired bowl and stir until uniform.
    • Once the soapy water is homogenous, add the individual keys and let them sit in the mixture for 30 minutes.
  4. Logitech K360 Cleaning and Key Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While waiting for the key to soak for the specified time, use a compressed air can to remove any dust particles under the keys. Do this by aiming the can's nozzle into any area that has dust build-up and begin to spray.
  5. Logitech K360 Cleaning and Key Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech K360 Cleaning and Key Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a small bristle brush to remove any dust present on the keyboard, especially in areas that are not visible when keys are connected. In this step, a make-up brush is used.
  6. Logitech K360 Cleaning and Key Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K360 Cleaning and Key Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K360 Cleaning and Key Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the 30-minute timer is up, remove the keys from the soapy water and use a rag or paper to dry them. Dry by padding down keys until there is no visible or physical dampness on the keys.
  7. Logitech K360 Cleaning and Key Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place keys back in the correct spot and find a google image that shows the correct order of the keys to ensure that the key placements are correct.
  8. Logitech K360 Cleaning and Key Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech K360 Cleaning and Key Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech K360 Cleaning and Key Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reconnect the batteries in the battery compartment located on the backside of the keyboard, in the correct positive to negative position, and turn on the keyboard.
    • Turn on the computer and attempt to use the keyboard to make sure the keyboard is fully functional.
Stefano Blasoni
crwdns2935283:011/17/22crwdne2935283:0
316 crwdns2915208:0crwdne2915208:0
Have you happened to open up and see what is the switch issue? I've read on other sites some have received what sounds like not functioning keyboard that I'm guessing is due to the switch, since in my situation the switch seems to be not moving as freely as my other logitech keyboards and mice with the similar looking switch. Albeit mine is white and there doesn't appears to be an LED. Looks like there are what reads as Apple looking green color side of the switch for on and a redish-orange color side for off.
James Finch - crwdns2934203:0crwdne2934203:0
If you want to clean it, you need to disassemble it. That glossy area between the keys is a giant sticker...peel that off, and it will reveal screws and you can disassemble the keyboard, and clean it.
Ben Willis - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 170
crwdns2942667:0crwdne2942667:0 5,173
