If you can't see the letter on your key or the keys are getting stuck with every click on your Logitech MK345, you can reference this guide to learn how to remove your key properly. Keeping the keyboard clean is essential to its use, especially if you use it everyday. In order to figure out if this is the right guide for you check out the Troubleshooting Page to discover the exact issue.
Lay your keyboard so that the keys are facing up.
Find the key you need to replace.
Press down on the key beside it.
Use an iFixit opening tool to pry up the key you need to replace.
