Logitech Harmony Touch Battery Replacement
crwdns2869540:0crwdne2869540:0: 11.298
9
45
201
11.298
crwdns2955950:0crwdne2955950:0: 3
crwdns2960008:03crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 7
crwdns2959974:07crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 5
crwdns2959982:05crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931273:0crwdne2931273:0
    1. Logitech Harmony Touch Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Harmony Touch Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Harmony Touch Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Open the latch that accesses the charging port.
      • Remove the black sticker and remove the screw with the indicated screwdriver.
      • Take the plastic opening tool and run it down the side of the remote to pop the case open.
      • While doing this step, there are three wires that connect the two pieces. Be sure not to rip them out.
      • Detach the white clamp to partially disconnect the case from the motherboard.
    2. Logitech Harmony Touch Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Harmony Touch Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Harmony Touch Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Peel back the thin yellow plastic film and detach the clip found underneath.
      • Remove the screws that connect the motherboard to the case with the suggested screwdriver.
    3. Logitech Harmony Touch Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Harmony Touch Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Next, carefully remove the motherboard from the top piece of the case by lifting the bottom first, then pulling.
      • The motherboard is connected to the bottom part of the case.
    4. Logitech Harmony Touch Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Harmony Touch Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Harmony Touch Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Disconnect the clip that connects the battery to the motherboard.
      • The clip has black, red, and yellow wires connected to it.
      • Remove the plastic covering over the battery from the motherboard.
      • The battery may be glued to the back of the plastic guard.
      • If glued to the back of the guard, use the metal spudger to carefully pry the battery off.
Lennox Saliva-Rojas
crwdns2935283:009/25/17crwdne2935283:0
299 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S4-G2, Eyestone Fall 2017 crwdns2935289:0USF Tampa, Team S4-G2, Eyestone Fall 2017crwdne2935289:0
USFT-EYESTONE-F17S4G2
I got it done. It was not clear from the instructions what was supposed to happen with the small circuit board with the USB connector that is also holding the battery case in place. Turns out you need to remove yet another screw and then carefully work the battery case out from under that circuit board, which remains in place.
I spent quite a while looking for the “white clamp” at the end of step 1, I never found it and don’t think it existed on my remote.
I managed to break one of the red wires connected to the charging contact on the bank case, and then managed to break the other one while trying to fix the first one. Fortunately, I hauled out my trusty soldering iron — probably hadn’t used it in 20 years — and soldered both wires back into place.
The battery is charging now and seems to be working! Thanks for the guide.
David Troup - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Is this battery any different from the Logitech Harmony Ultimate One?
bruno kebran - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I think the “white clamp” that David is referring to is the “white connector” that the red arrow is pointing to. My battery was not glued in place but was held in place by double adhesive tape. Of course I reused it. Thank you for the guide.
Richard Kaapuni - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 45
crwdns2936753:030crwdne2936753:0 201
crwdns2959996:0crwdne2959996:0 11,298
