Logitech Harmony Smart Keyboard On/Off Switch Replacement
crwdns2869540:0crwdne2869540:0: 5595
3
21
120
5,595
crwdns2955950:0crwdne2955950:0: 2
crwdns2960002:01crwdne2960002:0, crwdns2960006:01crwdne2960006:0
crwdns2959984:0crwdne2959984:0: 2
crwdns2959974:02crwdne2959974:0
crwdns2955944:0crwdne2955944:0: 15 - 20 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
This is a replacement guide for the on/off switch on the Logitech Harmony Smart Keyboard.
The on/off switch, or power switch, powers the keyboard on and off. The on/off switch appears green when powered on, and appears red when powered off.
    1. Logitech Harmony Smart Keyboard On/Off Switch Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Harmony Smart Keyboard On/Off Switch Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn keyboard over to the backside.
    2. Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Press and slide up on the upper battery latch, using both thumbs.
    3. Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two AA batteries and set them aside.
    4. Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew all five 4.0 mm screws, using Phillips #1 screwdriver.
    5. Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Peel off the center sticker to reveal two hidden 4.0 mm screws.
      • Unscrew these two screws with a Phillips #1 screwdriver.
    6. Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift both top left and top right rubber stickers halfway, using the sharp end of the plastic spudger.
      • Unscrew a total of two 4.0 mm screws, under the rubber stickers, using a Phillips #1 screwdriver.
    7. Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew the top center 4.0 mm screw, in the battery compartment, using the Phillips #1 screwdriver.
      • Now, you should have a total of ten 4.0 mm screws set aside.
    8. Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Wedge the flat end of the spudger between the back panel and front panel.
      • Slide the flat end of the spudger from right to left to pry the two panels apart.
    9. Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Separate the back panel from the front panel completely, using both hands.
      • A white ribbon flex cable will remain connected to both panels.
      • Pull the panels apart slowly and gently, or the white ribbon flex cable may be unsafely removed.
    1. Logitech Harmony Smart Keyboard On/Off Switch Replacement, On/Off Switch: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Harmony Smart Keyboard On/Off Switch Replacement, On/Off Switch: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Harmony Smart Keyboard On/Off Switch Replacement, On/Off Switch: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Grip the lower end of the ribbon flex cable (white band) using your thumb and index finger.
      • Then slide the strip out toward yourself in a scooping motion.
      • Now, you should have two completely separated panel pieces.
    2. Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Set aside the front panel and locate the green card atop the on/off switch on the back panel.
      • Unscrew the two 4.0 mm screws on either side of the green card using a Phillips #1 screwdriver.
    3. Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Harmony Smart Keyboard On/Off Switch Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift up and hold the left side of the green card with one index finger.
      • Grip and pull the on/off switch out with your other index finger and thumb.
Hayley Nichols
crwdns2935283:009/05/17crwdne2935283:0
525 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team S1-G2, Bruce Fall 2017 crwdns2935289:0CSU Fullerton, Team S1-G2, Bruce Fall 2017crwdne2935289:0
CSUF-BRUCE-F17S1G2
please share switch rear side.. and where could we buy this switch.. ?
Praveen Krishnan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 120
crwdns2959996:0crwdne2959996:0 5,595
