This is a replacement guide for the Logitech Harmony Smart Keyboard's key printed circuit board.
The keyboard printed circuit board (PCB) sends messages to the wifi and transmits key data to the server.
Turn keyboard over to the backside.
Press and slide up on the upper battery latch, using both thumbs.
Remove the two AA batteries and set them aside.
Unscrew all five 4.0 mm screws, using Phillips #1 screwdriver.
Peel off the center sticker to reveal two hidden 4.0 mm screws.
Unscrew these two screws with a Phillips #1 screwdriver.
Lift both top left and top right rubber stickers halfway, using the sharp end of the plastic spudger.
Unscrew a total of two 4.0 mm screws, under the rubber stickers, using a Phillips #1 screwdriver.
Unscrew the top center 4.0 mm screw, in the battery compartment, using the Phillips #1 screwdriver.
Wedge the flat end of the spudger between the back panel and front panel.
Slide the flat end of the spudger from right to left to pry the two panels apart.
Separate the back panel from the front panel completely, using both hands.
Grip the lower end of the ribbon flex cable (white band) using your thumb and index finger.
Then slide the strip out toward yourself in a scooping motion.
Lift and remove the white rubber sheet that lays over the keyboard pet flexible PCB.
Unscrew the two 4.0 mm screws on either side of the green card using a Phillips #1 screwdriver.
Lift the green card up using the flat end of the plastic spudger.
Grip and lift the keyboard PCB up and out.
Grip and lift the battery wire bar out of the battery compartment, using your thumb and index finger.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Pinch your precision tweezers and wedge the battery clamp up.
Lift the entire keyboard PCB out of the panel.
Slide your index finger into the slot under the right blue tab.
Pinch and pull the right blue tab away from the green card.
Pinch and pull the left blue tab away from the green card.
This is really very informative to read and helpful while replacement or cleaning theprinted circuit board . I really want my friend companies engineer to read this type of information and work on it in practical. i wanna tag that company here as well @XG-technologies (https://xg-pcb.com/). Moreover keep sharing these type of informative blogs. really liked it.
dnde cmprar el recambi, cm se ve n funcina la 0
