Logitech Harmony Smart Control Charging Port Replacement
  1. Logitech Harmony Smart Control Charging Port Replacement, Charging Port: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Harmony Smart Control Charging Port Replacement, Charging Port: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to lift up the rubber pad.
    • With your fingers, pull back the rubber pad. This will expose the screw holes on the bottom of the device.
    • Repeat the step above for the second rubber pad on the bottom of the hub.
  2. Logitech Harmony Smart Control Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Harmony Smart Control Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the PH00 bit, remove the four 6mm Phillips screws
  3. Logitech Harmony Smart Control Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Harmony Smart Control Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to pry open and separate the pieces of plastic from each other.
  4. Logitech Harmony Smart Control Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Harmony Smart Control Charging Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the PH00 bit, remove the three 4mm Phillips screws.
  5. Logitech Harmony Smart Control Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Harmony Smart Control Charging Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Harmony Smart Control Charging Port Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting at the yellow corner, use a plastic opening tool to pry the circuit board from the housing.
  6. Logitech Harmony Smart Control Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Harmony Smart Control Charging Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Harmony Smart Control Charging Port Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the defective charging port.
    • Turn the circuit board over to expose the charging solder.
    • Using a soldering iron, remove the solder and the charging port. Install a new charging port and solder.
Josh Hendricks
crwdns2935283:009/17/15crwdne2935283:0
464 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-2, Harley Fall 2015 crwdns2935289:0IUPUI, Team 3-2, Harley Fall 2015crwdne2935289:0
IUPUI-HARLEY-F15S3G2
crwdns2942667:0crwdne2942667:0 855
