Logitech Harmony 950 Case Replacement
Shiba Kandel
crwdns2944107:0crwdnd2944107:0Shiba Kandelcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:06crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mud 16, 2024crwdne2944111:0
crwdns2931287:020crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
This guide will involve using basic tools to replace the case of the Logitech Harmony 950.
crwdns2944105:0crwdne2944105:0
  1. Logitech Harmony 950 Case Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Harmony 950 Case Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure the remote control is powered off before starting.
    • Use the Opening Tool to open the port cover at the bottom of the remote control.
    • Bend the cover back to gain easy access to the screws.
  2. Logitech Harmony 950 Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Harmony 950 Case Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Harmony 950 Case Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #0 Screwdriver to remove the (2) two 6mm screws.
    • Pull the bottom cover off of the remote control.
  3. Logitech Harmony 950 Case Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Harmony 950 Case Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Harmony 950 Case Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #1 Screwdriver to remove the (2) two 6mm screws.
    • There should be a gap on each side to fit the Opening Tool. Use the Opening Tool to open the back cover (Soft Touch cover) using the gap.
  4. Logitech Harmony 950 Case Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Harmony 950 Case Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Harmony 950 Case Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Opening Tool to lift the battery out of the case.
    • Gently pull the cable out of the socket to unplug the battery.
    • Be careful not to damage any part of the remote when pulling the cable out.
  5. Logitech Harmony 950 Case Replacement, Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Harmony 950 Case Replacement, Case: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Harmony 950 Case Replacement, Case: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #1 screwdriver to remove the (3) three 6mm screws.
    • Push the opening tool into the gap along the side of the remote, then slide it across until you hear clicking sounds.
    • You need to repeat this process for both sides of the remote.
  6. Logitech Harmony 950 Case Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Harmony 950 Case Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Harmony 950 Case Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    $3.99
    • Carefully remove the back cover and place it next to the remote. Be careful not to detach the wire during this process.
    • Use the angled Tweezers to carefully pull the white cable end off of the remote and disconnect it.
  7. Logitech Harmony 950 Case Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Harmony 950 Case Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Harmony 950 Case Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #0 screwdriver to remove the (5) five 6mm screws. Keep in mind that once the screws are off, the circuit board will be completely separate from the case.
    • Be careful not to damage or disconnect the pink wires when removing the gold charging conductors from the case.
  8. Logitech Harmony 950 Case Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Harmony 950 Case Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Harmony 950 Case Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the black tape to fully access the cable underneath.
    • This cable has a locking mechanism. Use the Angled Tweezers to lift the black part (lock).
    • Slide the yellow cable to disconnect it from the circuit board.
  9. Logitech Harmony 950 Case Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Harmony 950 Case Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the circuit board off of the case. Start from the bottom, and lift up to completely detach it from the cover.
  10. Logitech Harmony 950 Case Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Harmony 950 Case Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Harmony 950 Case Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Blunt Tweezers to carefully remove the keypad from the cover of the remote.
Shiba Kandel
crwdns2935283:009/26/17crwdne2935283:0
149 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G2, Passmore Fall 2017 crwdns2935289:0USF Tampa, Team S2-G2, Passmore Fall 2017crwdne2935289:0
USFT-PASSMORE-F17S2G2
where can this casing be purchased?
Sharonda Bailey - crwdns2934203:0crwdne2934203:0
Parts are required obviously!!
larrybud2004 - crwdns2934203:0crwdne2934203:0
Is the usb bottom cap part of the replacement case? If not can u get one?
jmorrissette - crwdns2934203:0crwdne2934203:0
Hello,
short question: does someone know, if and where you can get a replacement case for Harmony 950 remote control?
Thx in advance
D. Schick - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,236
