Logitech Harmony 900 Button Pad Replacement
    1. Logitech Harmony 900 Button Pad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Harmony 900 Button Pad Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Press the oval shaped button on the lower back of the remote to release the battery cover.
      • While pressing the button, remove the cover.
    2. Logitech Harmony 900 Button Pad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Harmony 900 Button Pad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Push the battery in, pull it up, and slide it out.
    1. Logitech Harmony 900 Button Pad Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using tweezers, peel off the sticker located under the battery cover to reveal two screws.
    2. Logitech Harmony 900 Button Pad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Harmony 900 Button Pad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Locate and unscrew the four 50mm screws using the Philips #0 screwdriver.
    3. Logitech Harmony 900 Button Pad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a credit card to pry the black, plastic, back cover off of the device.
      • You may need to get the process started with a metal prying tool before you start using the credit card.
    4. Logitech Harmony 900 Button Pad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Harmony 900 Button Pad Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Locate the three 50mm screws on the back of the remote and remove them using the Phillips #0 screwdriver.
    5. Logitech Harmony 900 Button Pad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Harmony 900 Button Pad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pry the black, front face of the remote from the back silver part by inserting a credit card in between and sliding down.
      • Again, you may need to use a metal prying tool to get the separation started.
    6. Logitech Harmony 900 Button Pad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Harmony 900 Button Pad Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • When you look at the circuit board, you should see a ribbon attaching the board to the plastic casing.
      • A little lever is holding the ribbon in place. Lift the lever with your nail or a 2.5mm flat-head screwdriver. Move the ribbon away from the circuit board.
    7. Logitech Harmony 900 Button Pad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Harmony 900 Button Pad Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the Philips #0 screwdriver, remove the three 50mm screws from the circuit board.
    8. Logitech Harmony 900 Button Pad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using your hands, carefully separate the motherboard from the rest of the remote.
    1. Logitech Harmony 900 Button Pad Replacement, Button Pad: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Harmony 900 Button Pad Replacement, Button Pad: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Peel off the button pads from the device frame.
Tyler Hanks
crwdns2935283:009/25/17crwdne2935283:0
442 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S4-G5, Eyestone Fall 2017 crwdns2935289:0USF Tampa, Team S4-G5, Eyestone Fall 2017crwdne2935289:0
USFT-EYESTONE-F17S4G5
crwdns2935297:048crwdne2935297:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 1,142
