Logitech Gamepad F310 Case Replacement
crwdns2869540:0crwdne2869540:0: 1K
3
20
84
1,032
crwdns2955950:0crwdne2955950:0: 1
crwdns2960002:01crwdne2960002:0.
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:010crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
Use this guide to replace a damaged or cracked controller case on your Logitech Gamepad F310. The controller case is what holds your controller together. That is reason to replace controller case.
Follow this guide in order to replace your Logitech Gamepad F310 controller case.
No special tools or skills required.
    1. Logitech Gamepad F310 Case Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Gamepad F310 Case Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
    2. Logitech Gamepad F310 Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Gamepad F310 Case Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Press along the seams of the controller and gently pull the front and rear case apart.
      • If necessary, use an opening tool to help pry the front and rear case apart.
      • Make sure to open the controller with the front facing down so that the buttons do not fall out.
    3. Logitech Gamepad F310 Case Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Separate the front and rear case.
      • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
    1. Logitech Gamepad F310 Case Replacement, Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Gamepad F310 Case Replacement, Case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #1 screwdriver to remove:
      • Four 3 mm screws
      • One 5 mm screw
      • Remove the central silver screw last.
      • Gently lift the motherboard off of the back case and slide the cord out of the slot on top.
You have successfully taken the case off of your controller! Using the new case, follow these steps in reverse order to assemble your fixed controller.
Alan Mendoza DracoKing
crwdns2935283:002/05/24crwdne2935283:0
197 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 2-6, Kilpatrick Spring 2024 crwdns2935289:0University of North Texas, Team 2-6, Kilpatrick Spring 2024crwdne2935289:0
UNT-KILPATRICK-S24S2G6
crwdns2936753:030crwdne2936753:0 84
crwdns2959996:0crwdne2959996:0 1,032
