Logitech G915 TKL G1-G8 Key Replacement
  1. Logitech G915 TKL G1-G8 Key Replacement, Remove the keycaps: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G915 TKL G1-G8 Key Replacement, Remove the keycaps: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G915 TKL G1-G8 Key Replacement, Remove the keycaps: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all the keycaps.
    • While it can be done barehanded, use of a flat tool to remove the keycaps or use a keycap puller is recommended to prevent damage.
  2. Logitech G915 TKL G1-G8 Key Replacement, Unscrew the front: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the front 2mm #00 Phillips screws found here.
  3. Logitech G915 TKL G1-G8 Key Replacement, Take out the battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G915 TKL G1-G8 Key Replacement, Take out the battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G915 TKL G1-G8 Key Replacement, Take out the battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery.
    • This will require the removal of the back sticker and unscrewing the two 2.5mm #0 Phillips screws circled.
  4. Logitech G915 TKL G1-G8 Key Replacement, Unscrew the back: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the remaining 2mm #00 Phillips back screws.
    • 3 screws are hidden under the rubber rests of the keyboard.
  5. Logitech G915 TKL G1-G8 Key Replacement, Unscrew the motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2mm #00 Phillips motherboard screws.
    • The G1-G8 keys are held in place by the motherboard itself. Once the motherboard is detached, they can be easily removed and replaced by hand.
Brandon Souza
crwdns2935283:003/13/23crwdne2935283:0
151 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-6, Petersen Spring 2023 crwdns2935289:0UMass Dartmouth, Team 3-6, Petersen Spring 2023crwdne2935289:0
UMASSD-PETERSEN-S23S3G6
I can't find anywhere to buy a replacement key, can you point to a place where this is available?.
Magnus - crwdns2934203:0crwdne2934203:0
"Once the motherboard is detached, they can be easily removed and replaced by hand."
Except you can't! The motherboard and all the key switches are slightly overlapped. Unless you de-soldering all the switch, you can not change the G keys. Stupid solution from Logitech in a such expensive keyboard
János G. - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 158
crwdns2942667:0crwdne2942667:0 4,703
