Use this guide to replace the lights of your Logitech G910.
Unplug the keyboard from the computer.
Flip the keyboard and unscrew the 15 back screws. The screws in the palm rest must be unscrewed and the palm rest removed to access the 6 screws at the bottom of the keyboard. (There are 2 lengths of screws the shorter ones are for the palm rest) There are also 2 screws under the nonslip pads of the palm rest.
doesn’t mention unscrewing the screws under the palmrest to remove the plastic under the palmrest to get at the back screws underneath
There are three screws located under the plastic feet, one in the center and one on each side.
Release the front part using a spudger or flat screwdriver to gently pry. Lift off carefully.
Step 2a: remove the 7 screws on the back of the keyboard towards the top (including 2 under the arx Dock)
Step 2b: remove the 8 screws from the back of the wrist rest
Step 2c: remove the back of the wrist rest
Step 2d: I've already removed 15 screws as per this guide, but there are 6 more under the wrist rest, should these be removed?
Step 2e: somehow remove the plastic trim that comprises the rest of the wrist rest and the keyboard surround. This is where I'm stuck, I can't remove this.
This guide to disassembly basically is “step 1: just disassemble the keyboard”
Gently lift up the plastic film in the top right corner.
crwdns2935229:05crwdne2935229:0
So what do I do after I take apart my keyboard?
this guide is currently missing some steps. If you have figured it out, pls edit this guide.
tayola -
Desolder and replace LEDs the size of a grain of sand xD
This is definitely not a job I'd mark as "easy".
