Logitech G710+ Disassembly
Jackson Poer
crwdns2944107:0crwdnd2944107:0Jackson Poercrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Ndz 17, 2020crwdne2944111:0
10 - 20 crwdns2931279:0crwdne2931279:0
crwdns2937799:0crwdne2937799:0
crwdns2944444:0crwdne2944444:0
  • Spudger
    Spudger
crwdns2944105:0crwdne2944105:0
  1. Logitech G710+ Disassembly, Body: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 14 Phillips screws on the bottom of the kayboard.
    • Use a plastic tool to release the clips holding the case together.
    • There are two hidden clips above the left and right arrow keys.
    • Gently pry the two halves of the case apart.
    • Don't worry if any of the clips break, the screws will still hold the keyboard together once reassembled.
    I broke the top left corner of the cover when I tried to open it… Good luck only breaking the clips… I didnt even apply much force at all.
    guillaume_b - crwdns2934203:0crwdne2934203:0
  2. Logitech G710+ Disassembly, Mother board: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G710+ Disassembly, Mother board: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G710+ Disassembly, Mother board: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the one screw holding on the ground and pull out the cables.
    • A good way of getting the cables out is by putting a screwdriver right there and twisting.
    • Unscrew this screw
    So what about the screw right above and between F6 and F7?
    MaybeCrispyWaffles - crwdns2934203:0crwdne2934203:0
  3. Logitech G710+ Disassembly, Scroll Wheel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The light thing comes out with a wiggle.
    • The scroll wheel on the other is harder because you have to melt or brake the supports off.
    • Then you have to get the wheel out which comes out with a very gentle wiggle.
  4. Logitech G710+ Disassembly, Pads: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can then take off the little pads
Jackson Poer
crwdns2935283:004/08/17crwdne2935283:0
683 crwdns2915208:0crwdne2915208:0
Okay but then how do remove the Silver screw at the top of the keyboard, next to the grounded screw?
step 2, 3rd picture “undo this screw” did not exist on my G710+. rather it had 3 screws one on the botom with a tab and one above the 2 key and one upper left of the insert key.
as for captains question, since i’m replying you get it after removing the motherboard from the back.
wildcat_15au - crwdns2934203:0crwdne2934203:0
Is there a video or illustration defining how the space bar works and is installed or removed? I cant figure out where the stabilizer bar actually sits
Rick Painter - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 66
crwdns2942667:0crwdne2942667:0 8,770
