If your Logitech G703 Lightspeed mouse (model 910-005638) scroll wheel is malfunctioning or not working, use this guide to replace the scroll wheel.
The scroll wheel is a important component of a mouse, as it helps browsing the internet and performing work-related tasks more easier. As it allows quicker navigation to find what they are looking for. This benefit extends to those who use the mouse for gaming or other purposes.
To learn more, Logitech has a manual supporting this device.
Flip the switch to OFF before proceeding.
Take the mouse skates off by using the flathead screwdriver.
Unscrew the four 5.4 mm countersunk screws using the Phillips #00 screwdriver.
Pull apart the two halves of the mouse.
Unscrew the two 4.9 mm countersunk screws using the Phillips #00 screwdriver.
Unscrew the two 4.7 mm countersunk screws that secure the scroll wheel in using the Phillips #00 Screwdriver.
Remove the rubber piece protecting the scroll wheel.
Detach the scroll wheel from the white plastic piece and replace.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
¿Hola, cual es la altura del switch de la rueda del mouse?
