Logitech G602 Side Motherboard Replacement
  1. Logitech G602 Side Motherboard Replacement, Side Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a blue spudger to pry all 4 mice feet from the bottom of the mouse.
  2. Logitech G602 Side Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm) from underneath the mice feet.
  3. Logitech G602 Side Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G602 Side Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the blue spudger to prop open the bottom battery port.
    • Remove the AA batteries.
  4. Logitech G602 Side Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the top of the mouse from the base of the mouse (separate the mouse in half) to expose the internal hardware.
  5. Logitech G602 Side Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G602 Side Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to grip and pull the white ribbon cable from the motherboard.
  6. Logitech G602 Side Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove both screws (3x5mm ) from above the side motherboard.
  7. Logitech G602 Side Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver and unscrew both screws from the side motherboard.
    • We used a set of pliers and a Phillips #00 screw bit because the screwdriver couldn't fit into the side of the device.
  8. Logitech G602 Side Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a black spudger and your fingers to loosen and remove the side motherboard.
Matthew Ross
crwdns2935283:001/17/18crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S1-G1, Ramos Winter 2018 crwdns2935289:0Eastern Washington University, Team S1-G1, Ramos Winter 2018crwdne2935289:0
EWU-RAMOS-W18S1G1
Is the white momentary switch the middle click button?
I have a couple of G602's that have failing middle click buttons, and if it's the momentary switch, it looks like an easy fix.
Agit - crwdns2934203:0crwdne2934203:0
G5 Button was sticking. Followed guide, I did not need spudger. Brushed board and buttons with toothbrush and alcohol. Button works now, thanks!
P Kemp - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 4,699
