Logitech G432 Audio Cable Replacement
  1. Logitech G432 Audio Cable Replacement, Earpad Cushions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G432 Audio Cable Replacement, Earpad Cushions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the cushion upward using your hands.
  2. Logitech G432 Audio Cable Replacement, Audio Cable: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G432 Audio Cable Replacement, Audio Cable: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G432 Audio Cable Replacement, Audio Cable: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 1.0 mm screws from the edge of the earpiece using a Phillips #0 screwdriver.
    • Use the pointed end of a spudger to remove the black sticker covering the fourth screw.
    • Remove the single 1.0 mm screw from beneath the sticker using a Phillips #0 screwdriver.
  3. Logitech G432 Audio Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently open the headpiece to prevent accidentally pulling apart any of the internal wiring.
  4. Logitech G432 Audio Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Raise the small component fastened to the wiring at the bottom of the earpiece to reveal each wire.
  5. Logitech G432 Audio Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Extend the wiring to expose the tiny knots located along the audio cable.
    • Unravel the knots to disconnect the wires using a soldering iron, making it possible to connect the new audio cable.
    The missing information here is the wiring relationship between the connector and the circuitboard with the existing cable.
    Jack plug from tip to base:
    Tip1: Red wire (Left +)
    Band2: Black (Right +)
    Band3: Gold/Blue/Green shields (Left -, Right -, Mic -)
    Band4: White (Mic +)
    On the circuit board the 6 connections from left to right are:
    (R+), (R-), (L+), (L-), (Mic-), (Mic+)
    R- and L- are definitely connected together on the board, so you don’t need to solder to both R- and L- if it’s not convenient. I’m not sure if Mic- is also connected.
    Dr Woo Woo Bingo Bongo - crwdns2934203:0crwdne2934203:0
Lara Vasquez
crwdns2935283:002/24/23crwdne2935283:0
412 crwdns2915208:0crwdne2915208:0
Marist, Team 1-2, Chaterdon Spring 2023 crwdns2935289:0Marist, Team 1-2, Chaterdon Spring 2023crwdne2935289:0
MARS-CHATERDON-S23S1G2
Vous pourriez mettre la référence du câble ?
Jean Morlet - crwdns2934203:0crwdne2934203:0
pour le moins tuto incomplet , on aimerai voir effectivement le replacement du cable, en effet, le cable d'origine comporte 6 conducteurs alors que les cables de remplacement n'en comportent que 4. La réparation ne s'arrete donc pas à remplacer les fils un par un (en plus la couleur des fils n'est pas la meme qu'à l'origine) il faut modifier le cablage d'origine : déplacer une tresse de masse et souder 2 straps......
marc miettaux - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 142
crwdns2942667:0crwdne2942667:0 3,164
