Logitech G432 Audio Cable Replacement
  1. Logitech G432 Audio Cable Replacement, Earpad Cushions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G432 Audio Cable Replacement, Earpad Cushions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the cushion upward using your hands.
  2. Logitech G432 Audio Cable Replacement, Audio Cable: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G432 Audio Cable Replacement, Audio Cable: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G432 Audio Cable Replacement, Audio Cable: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 1.0 mm screws from the edge of the earpiece using a Phillips #0 screwdriver.
    • Use the pointed end of a spudger to remove the black sticker covering the fourth screw.
    • Remove the single 1.0 mm screw from beneath the sticker using a Phillips #0 screwdriver.
  3. Logitech G432 Audio Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently open the headpiece to prevent accidentally pulling apart any of the internal wiring.
  4. Logitech G432 Audio Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Raise the small component fastened to the wiring at the bottom of the earpiece to reveal each wire.
  5. Logitech G432 Audio Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Extend the wiring to expose the tiny knots located along the audio cable.
    • Unravel the knots to disconnect the wires using a soldering iron, making it possible to connect the new audio cable.
Lara Vasquez
crwdns2935283:002/24/23crwdne2935283:0
412 crwdns2915208:0crwdne2915208:0
Marist, Team 1-2, Chaterdon Spring 2023 crwdns2935289:0Marist, Team 1-2, Chaterdon Spring 2023crwdne2935289:0
MARS-CHATERDON-S23S1G2
Vous pourriez mettre la référence du câble ?
Jean Morlet - crwdns2934203:0crwdne2934203:0
pour le moins tuto incomplet , on aimerai voir effectivement le replacement du cable, en effet, le cable d'origine comporte 6 conducteurs alors que les cables de remplacement n'en comportent que 4. La réparation ne s'arrete donc pas à remplacer les fils un par un (en plus la couleur des fils n'est pas la meme qu'à l'origine) il faut modifier le cablage d'origine : déplacer une tresse de masse et souder 2 straps......
marc miettaux - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 39
crwdns2936753:030crwdne2936753:0 132
crwdns2942667:0crwdne2942667:0 3,961
