By using this detailed guide, you can learn how to replace the Logitech G305 scroll wheel in 7 easy steps. Replacing a scroll wheel in a mouse is not as simple as it sounds, and takes a couple of tools to get the job done.
These tools are a crucial part of the process, and help to get it done. This repair is an essential part of larger mouse up-keep, and it helps to make sure the scroll wheel is working as it was meant to. By using this guide, you will understand how to successfully replace the scroll wheel for your Logitech G305 mouse using the tools below.
crwdns2935267:0crwdne2935267:0Flathead 1.5 mm Screwdriver$5.49
Use a 1.5 mm flathead screwdriver to remove the four mouse skates from the bottom of the mouse.
Use a Phillips #00 screwdriver to remove the four bottom case screws.
Remove the palm cover by simply sliding downwards. Remove the battery and the bluetooth usb.
Using a flat head screwdriver 1.5mm to not pry but to adjust the connector. By doing this it will allow you to open the inside.
Using the flathead screwdriver 1.5mm you can undo the clip holding the wiring in place.
There is a metal spring that holds one side of the scroll wheel, remove the metal spring using a flathead screwdriver 1.5mm and lifting the scroll wheel.
Use a Phillips screw driver #00 to remove the four screws.
Using the Flathead screwdriver 1.5mm, disconnect the clip for the green and blue wire.
Remove the motherboard out of the casing.
The mouse wheel can only come out one way. Slide to the right to release mouse wheel.
crwdns2935229:010crwdne2935229:0
Should you encounter issues with a malfunctioning scroll wheel, consider cleaning it using a can of compressed air and then applying a small amount of PTFE-based multi-use synthetic oil to the scroll wheel housing.
