Logitech G29 Steering Wheel Motherboard Replacement
  1. Logitech G29 Steering Wheel Motherboard Replacement, Steering Wheel Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 32mm long 4mm Allen screws from the faceplate of the steering wheel
  2. Logitech G29 Steering Wheel Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 10mm long #00 Phillips head screws from the back of the steering wheel. Rotate the steering wheel 60 degrees per screw until all 6 screws are removed.
    • Gently lift the steering wheel off the steering column
  3. Logitech G29 Steering Wheel Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently unplug the wiring harness from the circuit board.
  4. Logitech G29 Steering Wheel Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 6 10mm long #00 Philips head screws that hold the circuit board to the steering wheel.
  5. Logitech G29 Steering Wheel Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 8mm long #00 Philips head screws holding the smaller circuit board onto the steering wheel.
  6. Logitech G29 Steering Wheel Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the circuit board off the steering wheel. replace the circuit board with the new part.
  7. Logitech G29 Steering Wheel Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The replacement part should match this image. All buttons on the steering wheel are included on this circuit board.
Cray McCall
crwdns2935283:009/16/22crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-5, Virtue Fall 2022 crwdns2935289:0Western Carolina University, Team 1-5, Virtue Fall 2022crwdne2935289:0
WCU-VIRTUE-F22S1G5
crwdns2935297:013crwdne2935297:0
Thx I was an idiot that forgot to check that the switch was out of the way, hence why I needed to replace, so I don't really need instructions as of how to do it, and a recommendation: add that you should make where when reassembling you check that the switch matches up with the switch extension thing so everyone doesn't make my dumb mistake. I would not be here writing this message if I had made sure that switch was there on the second go around (I forgot to put the plastic protector on the metal stand mounts for attaching to a metal cockpit stand) so I found it oddly difficult to put the board back then snap... awkward silence plug in the wheel and it spins around, and mashes every single button, and repeats for hours until I unplug it defeated. All this from a dumb switch. Hope you enjoyed my whole life story... It actually kinda feels like my whole life story lol.
CHUCK SANNEL - crwdns2934203:0crwdne2934203:0
Hi,
I have a question, we replaced the regular wheel for an F1 mod wheel and since then it hasn't been working optimally the button with the circle doesn't work in game and in the menu it does again, do you guys have any idea what it could be ?
Tommy Edinger - crwdns2934203:0crwdne2934203:0
My wheel has adapter power, wheel calibrates perfectly but no LED light on the wheel itself and none of the buttons work. I've checked all connections from USB console/pc cable back to the main circuit board plug. I've also checked continuity between the wheel plug and the other end, the main board plug - all good.
So, I can steer a car in a game but none of the buttons work at all and no rev lights or green power light on wheel.
PS Just replaced the main board with a working replacement or so I've been told by the seller.
Philbo - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 50
crwdns2936753:030crwdne2936753:0 339
crwdns2942667:0crwdne2942667:0 15,555
