Logitech G29 Driving Force Pedal Replacement
  1. Logitech G29 Driving Force Pedal Replacement, Pedal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by orienting the pedal box onto its underside.
    • Remove the twelve #1 Phillips screws that secure the bottom cover to the pedals.
  2. Logitech G29 Driving Force Pedal Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the remaining twelve #0 Phillips screws from the bottom cover.
  3. Logitech G29 Driving Force Pedal Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the pedal, first take out the 2 Allen screws located in the middle of the pedals.
    • You only need to remove the screws out of the pedal that needs fixing. Any others can stay where they are.
  4. Logitech G29 Driving Force Pedal Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now that all screws are loose the back plate should be able to be removed revealing the pedals.
  5. Logitech G29 Driving Force Pedal Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If pedal is unresponsive start by checking the gear mesh.
    • If gear mesh is not connecting check to make sure everything is tight.
    • If gears are stripped or have broken off get replacement gears.
  6. Logitech G29 Driving Force Pedal Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If gears are fine check the wire connections.
    • If red wires are loose, resolder and make sure the connection is good.
    • If the black ground wire is loose, tighten it up.
    • If none of these fix the problem, source a replacement pedal.
Brock Harris
crwdns2935283:009/16/22crwdne2935283:0
350 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-5, Virtue Fall 2022 crwdns2935289:0Western Carolina University, Team 1-5, Virtue Fall 2022crwdne2935289:0
WCU-VIRTUE-F22S1G5
crwdns2935297:013crwdne2935297:0
Hola. Tengo un problema en el conexionamiento desde los potenciometros hasta el conector DIM9. ¿Alguien puede pasar Esquema Electrico para poder conexionar los distintos cables en los pins correspondientes?
EckoCharliE72 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 74
crwdns2936753:030crwdne2936753:0 298
crwdns2942667:0crwdne2942667:0 10,544
