Logitech G27 Pedal Spring Replacement
  1. Logitech G27 Pedal Spring Replacement, Pedal Spring: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two screws from each pedal with a 2.5mm allen wrench.
    • The left two pedals have 30 mm screws and the right-most pedal has 16.3 mm screws.
    • Once these screws are off, take off the front faces on each pedal, they should be very easy to remove.
  2. Logitech G27 Pedal Spring Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G27 Pedal Spring Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip over the device. Now remove fourteen 15.8 mm screws from the underside of the pedal assembly with a Phillips #1 screwdriver.
    • There are two of these screws under the carpet grip, make sure you don't miss those!
    • When finished, flip over the device again so that it's in its original position.
  3. Logitech G27 Pedal Spring Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G27 Pedal Spring Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G27 Pedal Spring Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the top cover of the device from the front, don't completely remove it yet though, because there are still wires connecting both halves. (NEED PICTURE)
    • Behind the left-most pedal, there are two 7.4mm screws attaching a wire to the top cover. Remove these with a Phillips #1 screwdriver and release the wires.
    • Once the wires are no longer connected to the top cover, remove the cover completely.
  4. Logitech G27 Pedal Spring Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G27 Pedal Spring Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Simultaneously remove the 10mm screws connecting the pedal to the red piston behind it.
    • This will take two 2.5mm allen wrenches, one for each side of the screw.
    • Once removed, the piston can rotate free of the pedal.
  5. Logitech G27 Pedal Spring Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the piston away from the pedal and remove the top half of it. The spring should now be visible. (NEED PICTURE)
    • Take out the spring, and replace it with a new one.
    • Repeat steps four and five for each pedal that needs a spring replaced.
crwdns2935229:010crwdne2935229:0
Grant Blake
crwdns2935283:004/21/15crwdne2935283:0
1,782 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-4, Amido Spring 2015 crwdns2935289:0Cal Poly, Team 15-4, Amido Spring 2015crwdne2935289:0
CPSU-AMIDO-S15S15G4
crwdns2935297:025crwdne2935297:0
I replaced the springs and reassembled in reverse order. However, my wheel will no longer power on. Any idea where I would have lost power? Thank you.
matthew.liam.gleason - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 182
crwdns2942667:0crwdne2942667:0 23,001
