Logitech G203 Mouse Scroll Wheel Replacement
  1. Logitech G203 Mouse Scroll Wheel Replacement, Scroll Wheel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G203 Mouse Scroll Wheel Replacement, Scroll Wheel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a sharp edge (a knife or a flat-headed screwdriver), remove the top two mouse skates by wedging your tool of choice underneath the skates. Then pry and remove the skates.
    • Be careful not to damage the skates as you will be reusing these after this procedure is done.
  2. Logitech G203 Mouse Scroll Wheel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G203 Mouse Scroll Wheel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 0.4 mm #1 Phillips screws underneath the top two skates and the third 0.4mm #1 Phillips screw under the sticker on the mouse.
    • For better access to the screw, you can remove the sticker itself.
  3. Logitech G203 Mouse Scroll Wheel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G203 Mouse Scroll Wheel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the two parts of the mouse, the top and the bottom by simply lifting the top.
  4. Logitech G203 Mouse Scroll Wheel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G203 Mouse Scroll Wheel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G203 Mouse Scroll Wheel Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your finger, pry apart the scroll wheel and the connector that keeps the scroll wheel in place. Once you do this, you should simply be able to pull the scroll wheel up.
  5. Logitech G203 Mouse Scroll Wheel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert your new scroll wheel into the same position that the old one was in. You will need to pry apart the connector once again to fit the scroll wheel in but be careful you do not damage the connector.
crwdns2935229:010crwdne2935229:0
Sabih Akram
crwdns2935283:009/20/20crwdne2935283:0
2 145 crwdns2915208:0crwdne2915208:0
York University, Team S13-G3, Allen Summer 2021 crwdns2935289:0York University, Team S13-G3, Allen Summer 2021crwdne2935289:0
YORK-ALLEN-SU21S13G3
It's difficult to replace the part when the PCB board is still screwed in. When I would disassemble it, I would unscrew the side buttons first then the motherboard (the screws are highlighted in white circles). From there try to remove the broken part at ease (Lift the motherboard and the side button motherboard from the housing). DO NOT try to pry it on step 4. You might broke something for that.
There's also phone repair toolkits that sells it on a cheaper price I would only use #00 Philips Screwdriver only and a spudger or a flathead screw to put the cables back in place when I disassembled it
Nicholin V - crwdns2934203:0crwdne2934203:0
On Step 1: You don't need to remove the skates if you want to rescrew it later. you can unscrew it the screws both sides and cover it later then move to the bottom hole (Don't forget to put some kind of tape on it). The screws are small and they're easy to lose them if not careful.
Can one get a replacement wheel somewhere? Does that fix scrolling problems, I'd have thought it was a sensor issue??
pbhj - crwdns2934203:0crwdne2934203:0
I wasn't able to use a metal replacement wheel I bought on Amazon. However, my issue with both the original wheel and the replacement (though the replacement was worse) was that the wheel was getting stuck, possibly on the PCB. Removing the rubber coating from the original wheel (recommended on a Reddit post I found) solved this problem. The wheel is now a bit smaller, has a smooth texture (no ridges like the original rubber), but it works fine. It's been months and I've gotten used to the different texture and size.
antonioban86 - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 17
crwdns2936753:07crwdne2936753:0 100
crwdns2936753:030crwdne2936753:0 422
crwdns2942667:0crwdne2942667:0 24,222
