Use this guide to replace the scroll wheel in a Logitech G1 optical mouse.
Sometimes the scroll wheel does not work when using the mouse. This guide not only shows you how to replace the mouse scroll wheel but also how to clean it.
Remove one screw at the bottom of the mouse.
Pull the top of the mouse lid gently to separate it from the rest of the mouse.
Pull the white connector from the circuit board.
Carefully remove the two Phillips #0 screws.
Clean the mouse case, lid, and module with a dry cotton swab or soft brush.
Place the new scroll wheel into the mouse.
The spring should be inserted into a small groove.
