Logitech G X56 HOTAS Throttle LED Board Replacement
  1. Logitech G X56 HOTAS Throttle LED Board Replacement, Label Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G X56 HOTAS Throttle LED Board Replacement, Label Plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 8.6 mm long 1.5 mm hex screws from the label plate.
  2. Logitech G X56 HOTAS Throttle LED Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an opening tool to pry off the mode switch knob.
  3. Logitech G X56 HOTAS Throttle LED Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G X56 HOTAS Throttle LED Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G X56 HOTAS Throttle LED Board Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the eight 12.5 mm long Phillips #1 screws from the underside of the label plate.
    • These screws are plastic! Be very careful when applying force.
  4. Logitech G X56 HOTAS Throttle LED Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G X56 HOTAS Throttle LED Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the throttle right side up again, using the bottom panel as a coaster.
    • Gently pry the label plate from the body of the throttle.
  5. Logitech G X56 HOTAS Throttle LED Board Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G X56 HOTAS Throttle LED Board Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Optional: Take a picture or mark each connector as you remove them for ease of reassembly.
    • Disconnect all of the motherboard connectors by pulling them straight up and out of their sockets.
  6. Logitech G X56 HOTAS Throttle LED Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G X56 HOTAS Throttle LED Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 11.6 mm-long Phillips #0 screws that secure the motherboard.
  7. Logitech G X56 HOTAS Throttle LED Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard from the base plate shell, carefully making sure to keep the USB power cable unstrained.
  8. Logitech G X56 HOTAS Throttle LED Board Replacement, LED Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G X56 HOTAS Throttle LED Board Replacement, LED Board: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Each LED Board uses the LEDs to hold it against the base plate. It also has a single cable set to the logic and power board.
  9. Logitech G X56 HOTAS Throttle LED Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G X56 HOTAS Throttle LED Board Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Each of the LEDs needs to be removed with a soldering iron and your choice of solder wick or solder sucker.
    • Once free of the solder, the LED must be pushed through to the front.
  10. Logitech G X56 HOTAS Throttle LED Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently Remove the LED board.
Elizabeth Matlock-Buchanan
crwdns2935283:002/22/25crwdne2935283:0
842 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 3-5, Sneed Spring 2025 crwdns2935289:0University of Memphis, Team 3-5, Sneed Spring 2025crwdne2935289:0
UM-SNEED-S25S3G5
crwdns2942667:0crwdne2942667:0 339
