Logitech G Pro X Superlight Scroll Wheel Replacement
  1. Logitech G Pro X Superlight Scroll Wheel Replacement, Scroll Wheel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G Pro X Superlight Scroll Wheel Replacement, Scroll Wheel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G Pro X Superlight Scroll Wheel Replacement, Scroll Wheel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Mouse skates will be damaged during this process. Having a new pair of mouse skates is STRONGLY recommended.
    • Use tweezers to peel off the mouse skates on the underside of the mouse.
  2. Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the six screws using a 1.6mm Phillips screwdriver on the top and bottom side of the mouse.
  3. Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the bottom shell with your hands.
    • Use caution, as wires are still intact.
    • The bottom shell should come off easily without applying any force.
  4. Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the wires and cables in contact with the sensor's motherboard.
    • Pull and shake evenly on the cable to make sure cables are not strained. Avoid pulling heavily.
  5. Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take out the battery located at the back of the mouse.
    • Flipping it upside down helps when removing it.
  6. Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four screws at the bottom part of the mouse with a 1.6mm screwdriver.
  7. Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully take out the left and right mouse buttons.
  8. Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four screws attached to the scroll wheel.
  9. Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply pressure and shake evenly to remove the attached cable.
    • The scroll wheel comes off easily without using too much pressure.
    • Insert the new scroll wheel and line up against the sensor.
  10. Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reattach the cable.
    • Refasten the four screws.
  11. Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to reinsert the four screws at the bottom half of the mouse and tighten with a screwdriver.
    • Attach the battery back on the bottom half of the mouse.
    • Reattach the two cables.
  12. Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Line up the bottom shell with the top shell and connect them together.
    • Reapply the four screws back onto the mouse.
  13. Logitech G Pro X Superlight Scroll Wheel Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put on your new mouse skates.
    • Apply pressure so that they stick to the mouse, leaving no air gap.
Zane
crwdns2935283:007/27/23crwdne2935283:0
388 crwdns2915208:0crwdne2915208:0
Thanks for publishing this!
Do you replace only plastic part of wheel or plastic wheel + PCB?
Where do you order new wheel?
Andriy Legayev - crwdns2934203:0crwdne2934203:0
https://ausmodshop.com/products/modded-l... pricy, but they have full replacement pcbs with all the parts installed for you so you
Daniel G -
I don't think the soft black part is separable for the original wheel. Ordered an 'original' (or mostly original 🙂) wheel at one famous giant Chinese marketplace for 6 USD, item id 1005006217893341 - couldn't find any difference
V S -
Thanks for the guide. Didn't need a new scroll wheel, but the disassembly guide was great.
Uber Beast - crwdns2934203:0crwdne2934203:0
Thanks for the guide. Some steps are not necessary if your purpose is just to change the wheel
V S - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 58
crwdns2936753:07crwdne2936753:0 344
crwdns2936753:030crwdne2936753:0 1,736
crwdns2942667:0crwdne2942667:0 73,671
