Logitech G Cloud L2-R2 Trigger Replacement
  1. Logitech G Cloud L2-R2 Trigger Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G Cloud L2-R2 Trigger Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power the device off and turn it over so the screen is face down.
    • Insert an opening pick into the seam between the back plate and left handguard.
    • Pry around the entire perimeter until the handguard fully releases.
    • Remove the handguard.
    • Repeat the previous three bullets on the right handguard.
  2. Logitech G Cloud L2-R2 Trigger Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove all eight 10 mm screws from the rear case located under where the handguards were.
  3. Logitech G Cloud L2-R2 Trigger Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G Cloud L2-R2 Trigger Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick into the seam between the midframe and rear case.
    • Gently pry the rear case upwards to separate it from the midframe.
  4. Logitech G Cloud L2-R2 Trigger Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove all seven 10 mm screws that secure the midframe.
  5. Logitech G Cloud L2-R2 Trigger Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G Cloud L2-R2 Trigger Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick into the seam between the midframe and front case at the top of the device to separate the interior plating.
    • Gently pry out the midframe by lifting an opening pick.
    • You may hear loud popping noises when you remove the interior plating. That's the sound of the retaining clips disengaging.
  6. Logitech G Cloud L2-R2 Trigger Replacement, L2-R2 Trigger: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech G Cloud L2-R2 Trigger Replacement, L2-R2 Trigger: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove all four 10 mm screws that secure the L2 and R2 triggers.
    • Pop the L2 and R2 triggers out with your fingers.
Spencer Davis
crwdns2935283:001/23/25crwdne2935283:0
517 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-1, Virtue Spring 2025 crwdns2935289:0Western Carolina University, Team 1-1, Virtue Spring 2025crwdne2935289:0
WCU-VIRTUE-S25S1G1
crwdns2942667:0crwdne2942667:0 43
