crwdns2959928:0crwdne2959928:0 ↓Replacing the case for the Logitech G Cloud is simple and can be accomplished in three steps. You will need a wedge tool and a Phillips #00 screwdriver. Carefully read the instructions before starting to disassemble the Logitech G Cloud. You may hear loud popping noises when you remove the casing.
Spudger4.9
Power the device off and turn it over so the screen is face down.
Insert an opening pick into the seam between the back plate and left handguard.
Pry around the entire perimeter until the handguard fully releases.
Remove the handguard.
Repeat the previous three bullets on the right handguard.
Use a Phillips #00 screwdriver to remove all eight 10 mm screws from the rear case located under where the handguards were.
Insert an opening pick into the seam between the midframe and rear case.
Gently pry the rear case upwards to separate it from the midframe.
Use a Phillips #00 screwdriver to remove all seven 10 mm screws that secure the midframe.
Insert an opening pick into the seam between the midframe and front case at the top of the device to separate the interior plating.
Gently pry out the midframe by lifting an opening pick.
