Logitech Extreme 3D Pro USB Cable Replacement
  1. Logitech Extreme 3D Pro USB Cable Replacement, Disassembly of the handle: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro USB Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro USB Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Extreme 3D Pro USB Cable Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro USB Cable Replacement, Disassembly of the base: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight 10mm Phillips #1 screws from the bottom.
    There is a 9th screw that you need to remove near the cable
    gigakoulis - crwdns2934203:0crwdne2934203:0
    I need a wiring diagram for the Logitech 3D Pro, I'm changing the Pots.
    Melvin L. Willms - crwdns2934203:0crwdne2934203:0
  5. Logitech Extreme 3D Pro USB Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Extreme 3D Pro USB Cable Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Extreme 3D Pro USB Cable Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the joystick upright.
    • Lift up the sliver base cover and feed the loose circuit board through.
    • Careful with the wires still attached to the silver base cover from the bottom of the joystick.
  6. Logitech Extreme 3D Pro USB Cable Replacement, USB Cable: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Extreme 3D Pro USB Cable Replacement, USB Cable: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull from the plug head straight up.
    • It may require some force to remove the cable. However be careful not to damage the wires.
Emanuel Canela
crwdns2935283:001/25/18crwdne2935283:0
1.321 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S7-G1, Passmore Spring 2018 crwdns2935289:0USF Tampa, Team S7-G1, Passmore Spring 2018crwdne2935289:0
USFT-PASSMORE-S18S7G1
What type of replacement cable do I need? Where can I purchase it?
Tom Tidbury - crwdns2934203:0crwdne2934203:0
Along with Tom, I would also like to know where I can get replacement parts for this joystick. I’ve been searching for a while now and can’t seem to find any spare parts for this joystick.
Clayton Noyes - crwdns2934203:0crwdne2934203:0
Savez-vous où l'on peut trouver cette pièce à l’achat ou à la récupération?
Jordan Stéphane Martinez - crwdns2934203:0crwdne2934203:0
Hey! @thetechchild I had a similar issue, couldn't find replacement parts after my cat chewed on the cable.. So I found an alternate solution, I bought some of these cables, some heat shrink tubing, and replaced the cable like this. Now I can detach a male to male USB A cable to the joystick and replace the cheap cable if it ever gets damaged again! Make sure to plug the cables into the pin connector in the exact same way that the original cable was plugged in: Green, White, Red, thin Black, thicker Black (left to right as shown in the images I linked above). I think I could have gotten a JST XH plug to better connect it, but doing the pins directly seems to be working fine for now. I'm not entirely sure if that's the correct plug, but from my research it looks like it.
William McCall - crwdns2934203:0crwdne2934203:0
Sadly same issue, tried all the linked products, looks like the design of the cables have changed. I cant get it to work even with the JST plug. Thanks for giving me a little hope though!
Dylan Brasier (Grim) - crwdns2934203:0crwdne2934203:0
Hey Dylan! I'm sorry yeah it seems like those connections don't work as expected - I tried them as well :( The joystick is still holding up with my original solution - perhaps that'll work well for you too! Good luck :)
William McCall -
crwdns2942667:0crwdne2942667:0 2,747
