After extended use, the USB cable may have become frayed or broken completely. This will require you to change the cable to continue using the joystick.
Remove these three Phillips #1 screws:
Two 10mm screws.
One 7mm screw.
Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
Remove the two 10mm Phillips #1 screws.
Pull apart the joystick chassis by hand.
Release this clip located underneath the hand rest
Remove the eight 10mm Phillips #1 screws from the bottom.
There is a 9th screw that you need to remove near the cable
I need a wiring diagram for the Logitech 3D Pro, I'm changing the Pots.
Flip the joystick upright.
Lift up the sliver base cover and feed the loose circuit board through.
Carefully pull from the plug head straight up.
What type of replacement cable do I need? Where can I purchase it?
Along with Tom, I would also like to know where I can get replacement parts for this joystick. I’ve been searching for a while now and can’t seem to find any spare parts for this joystick.
Savez-vous où l'on peut trouver cette pièce à l’achat ou à la récupération?
Hey! @thetechchild I had a similar issue, couldn't find replacement parts after my cat chewed on the cable.. So I found an alternate solution, I bought some of these cables, some heat shrink tubing, and replaced the cable like this. Now I can detach a male to male USB A cable to the joystick and replace the cheap cable if it ever gets damaged again! Make sure to plug the cables into the pin connector in the exact same way that the original cable was plugged in: Green, White, Red, thin Black, thicker Black (left to right as shown in the images I linked above). I think I could have gotten a JST XH plug to better connect it, but doing the pins directly seems to be working fine for now. I'm not entirely sure if that's the correct plug, but from my research it looks like it.
Sadly same issue, tried all the linked products, looks like the design of the cables have changed. I cant get it to work even with the JST plug. Thanks for giving me a little hope though!
Hey Dylan! I'm sorry yeah it seems like those connections don't work as expected - I tried them as well :( The joystick is still holding up with my original solution - perhaps that'll work well for you too! Good luck :)
