Logitech Circle Ribbon Cable Replacement
  1. Logitech Circle Ribbon Cable Replacement, Ribbon Cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Circle Ribbon Cable Replacement, Ribbon Cable: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge the plastic opening tool under the black circle lens and gently pry it off.
    • The lens is only attached with sticky tape and should remove relatively easily.
  2. Logitech Circle Ribbon Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Circle Ribbon Cable Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 3mm Phillips #0 screws that hold down the first ring.
  3. Logitech Circle Ribbon Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Circle Ribbon Cable Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 3mm Phillips #0 screws that hold down the second ring.
  4. Logitech Circle Ribbon Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Circle Ribbon Cable Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 3mm Phillips #0 screws that hold down the final ring. Do not remove the lens/battery bundle yet.
    • The lens/battery bundle is attached to the base by a ribbon cable that can break, so be very careful handling the circle.
  5. Logitech Circle Ribbon Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Circle Ribbon Cable Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the lens/battery bundle from the base of the circle, being mindful of the ribbon cable.
  6. Logitech Circle Ribbon Cable Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Circle Ribbon Cable Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the ribbon cable loose from the lens/battery bundle.
    • While this is not an entirely necessary step, it helps to ensure the ribbon cable will not break during the rest of the replacement.
  7. Logitech Circle Ribbon Cable Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech Circle Ribbon Cable Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech Circle Ribbon Cable Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the old ribbon cable has been detached from the lens/battery bundle it's time to release the other side from the base.
    • Locate the screws holding the base together by feeling for the soft spots underneath the manufacturer's sticker. Punch through with your screwdriver and remove the three 3mm Phillips #0 screws.
    • The two pieces of the base can now be easily pulled apart.
  8. Logitech Circle Ribbon Cable Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Circle Ribbon Cable Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the ribbon cable loose from its connection to the base.
  9. Logitech Circle Ribbon Cable Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Circle Ribbon Cable Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the push pin holding the plastic connector/ribbon cable in place out on both sides.
  10. Logitech Circle Ribbon Cable Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black plastic connector and the two springs from the base of the device.
  11. Logitech Circle Ribbon Cable Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reach inside the circle and pull the ribbon cable free from the device.
Haley Williams
crwdns2935283:009/28/17crwdne2935283:0
112 crwdns2915208:0crwdne2915208:0
University of Maine, Team S1-G4, Diaz Fall 2017 crwdns2935289:0University of Maine, Team S1-G4, Diaz Fall 2017crwdne2935289:0
UMAINE-DIAZ-F17S1G4
where can I buy such a cable?
kersop@gmail.com
Nico Kersop - crwdns2934203:0crwdne2934203:0
The cable I received from China is not the right one. Where do you buy the correct one?
Helen - crwdns2934203:0crwdne2934203:0
Can you advise where to buy the correct cable?
Michele Ingratta - crwdns2934203:0crwdne2934203:0
I have cable has beark off. I need that cable.
Where can I find
Alican Döşlü - crwdns2934203:0crwdne2934203:0
Where can I find this cable? I've tried everything even contacting Fox lol
Travis H. Childress - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,174
