Logitech Circle Battery Replacement
crwdns2869540:0crwdne2869540:0: 13.293
4
36
148
13.293
crwdns2955950:0crwdne2955950:0: 33
crwdns2960004:012crwdne2960004:0, crwdns2960008:021crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 6
crwdns2959974:06crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 2
crwdns2959982:02crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:015crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
This guide will allow you to remove and replace the battery inside of the Logitech Circle. This guide is fairly simple to follow, with only a few screws being between you and the battery itself. However, be sure to be careful handling the Logitech, as the battery and lens bundle is connected to the base of the circle with a ribbon that breaks relatively easily.
    1. Logitech Circle Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Circle Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Wedge the plastic opening tool under the black circle lens to gently pry it off.
      • The lens is only attached with sticky tape and should remove relatively easily.
    2. Logitech Circle Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 3mm Phillips #0 screws that hold down the first ring.
    3. Logitech Circle Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Circle Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four 3mm Phillips #0 screws that hold down the second ring.
    4. Logitech Circle Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Circle Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four 3mm Phillips #0 screws that hold down the final ring. Do not remove the lens/battery bundle yet.
      • The lens/battery bundle is attached to the base by a ribbon cable that can break, so be very careful handling the circle.
    5. Logitech Circle Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Circle Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently remove the lens/battery bundle from the base of the circle, being mindful of the ribbon cable.
    6. Logitech Circle Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech Circle Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently pull the ribbon cable loose from the lens/battery bundle.
      • While this is not an entirely necessary step, it helps to ensure the ribbon cable will not break during the rest of the battery replacement.
    7. Logitech Circle Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully unplug the battery from the rest of the lens.
    8. Logitech Circle Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery using a plastic opening tool. The battery is attached with sticky tape and will remove with gentle prying motions.
Kylie
crwdns2935283:009/28/17crwdne2935283:0
348 crwdns2915208:0crwdne2915208:0
University of Maine, Team S1-G4, Diaz Fall 2017 crwdns2935289:0University of Maine, Team S1-G4, Diaz Fall 2017crwdne2935289:0
UMAINE-DIAZ-F17S1G4
crwdns2935297:036crwdne2935297:0
crwdns2947412:021crwdne2947412:0
What about circle wireless batter with the unscrewBle lens? I keep getting error in set up that the battery is too low to proceed.
I charged only the battery portion all day. Stil. Same results
Diane Fischer - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where did you buy the battery? I can’t find something to replace it with :(
Razvan Ciocanel - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I measured my battery and it is 40mm x 14mm x 30mm. The space for the battery looks like I can fit something as long as 45mm. I can not find anything in the US. Going to try these: https://www.ebay.com/itm/3-7V-1200mAh-10.... Pretty annoying that I can not find something to drop in. The most challenging part of this repair is going to be wiring these two Lipos together properly. Does anyone know the voltage of the 3 wires? My battery is completely dead so I cannot get a voltage reading. I am going to have to plug the camera in, plug the battery connector in and get the voltage from there :)
Jonathan Flower - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hey, did you manage to make this work? I want to order some battery and try the same thing. I understand that you need 2 from the pictures. How are they tied together? You can not see that from this tutorial.
crwdns2936753:07crwdne2936753:0 36
crwdns2936753:030crwdne2936753:0 148
crwdns2959996:0crwdne2959996:0 13,293
