Logic Board Removal (Rear Cameras)
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Logic Board Removal (Rear Cameras), Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logic Board Removal (Rear Cameras), Safety precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
  2. Logic Board Removal (Rear Cameras), Adhesive information: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Adhesive information: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Adhesive information: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Adhesive secures the perimeter of the rear cover to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
    • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
  3. Logic Board Removal (Rear Cameras), Apply a suction handle: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logic Board Removal (Rear Cameras), Apply a suction handle: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
  4. Logic Board Removal (Rear Cameras), Insert an opening pick: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Insert an opening pick: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Insert an opening pick: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
    • Insert the tip of an opening pick in the gap.
  5. Logic Board Removal (Rear Cameras), Separate the rear cover adhesive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Separate the rear cover adhesive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Separate the rear cover adhesive: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide your opening along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Logic Board Removal (Rear Cameras): crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras): crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras): crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
  7. Logic Board Removal (Rear Cameras): crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras): crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras): crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide your pick down the right edge to separate the remaining adhesive.
  8. Logic Board Removal (Rear Cameras), Prop up the rear cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Prop up the rear cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Prop up the rear cover: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
    • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
  9. Logic Board Removal (Rear Cameras), Remove the wireless charging assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logic Board Removal (Rear Cameras), Remove the wireless charging assembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $31.41
    • While the Pixel 9 Pro uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP screwdriver to remove the five screws securing the wireless charging assembly:
    • Four 5.4 mm‑long screws
    • One 1.5 mm‑long screw
    • This screw is non‑magnetic—you may need to use tweezers to remove it.
  10. Logic Board Removal (Rear Cameras): crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras): crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras): crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be very careful not to damage the spring contacts under the top left edge of the wireless charging assembly.
    • Use tweezers or your fingers to remove the wireless charging assembly.
  11. Logic Board Removal (Rear Cameras), Disconnect the rear cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Disconnect the rear cover: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Disconnect the rear cover: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick under the left edge of the rear cover press connector and pry straight up to disconnect it.
  12. Logic Board Removal (Rear Cameras), Remove the rear cover: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rear cover.
    • During reassembly, follow this guide to apply new adhesive and install your rear cover.
  13. Logic Board Removal (Rear Cameras), Remove the cable cover: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logic Board Removal (Rear Cameras), Remove the cable cover: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP screwdriver to remove the two screws securing the cable cover:
    • One 2.3 mm‑long screw
    • One 5.4 mm‑long screw
  14. Logic Board Removal (Rear Cameras): crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logic Board Removal (Rear Cameras): crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingers to remove the cable cover.
  15. Logic Board Removal (Rear Cameras), Disconnect the battery: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Disconnect the battery: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Disconnect the battery: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of a spudger under the right edge of the battery press connector and pry straight up to disconnect it.
  16. Logic Board Removal (Rear Cameras), Remove the 5G mmWave cover screw: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logic Board Removal (Rear Cameras), Remove the 5G mmWave cover screw: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP screwdriver to remove the 5.4 mm‑long screw securing the mmWave antenna cover.
  17. Logic Board Removal (Rear Cameras), Unclip the 5G mmWave cover: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Unclip the 5G mmWave cover: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Unclip the 5G mmWave cover: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of a spudger under the clip near the bottom left corner of the mmWave antenna cover and pry up to unclip it.
  18. Logic Board Removal (Rear Cameras), Remove the 5G mmWave cover: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logic Board Removal (Rear Cameras), Remove the 5G mmWave cover: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the right edge of the cover towards the bottom of the phone and remove the cover.
    • During reassembly, insert the two tabs on the top corners under their recesses in the frame and push the cover down to clip it into place.
  19. Logic Board Removal (Rear Cameras), Disconnect the 5G mmWave antenna: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logic Board Removal (Rear Cameras), Disconnect the 5G mmWave antenna: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the mmWave antenna press connector from the top right corner of the logic board.
  20. Logic Board Removal (Rear Cameras), Disconnect the front facing camera: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logic Board Removal (Rear Cameras), Disconnect the front facing camera: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the front facing camera press connector.
  21. Logic Board Removal (Rear Cameras), Remove the 5G mmWave antenna screw: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Remove the 5G mmWave antenna screw: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Remove the 5G mmWave antenna screw: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be very careful not to touch the cameras during this step. If you accidentally do, wipe them with a clean microfiber or lint‑free cloth.
    • Carefully hold the front facing camera cable out of the way so you can access the mmWave antenna screw.
    • Use a Torx Plus 3IP screwdriver to remove the 4.3 mm‑long screw securing the mmWave antenna.
  22. Logic Board Removal (Rear Cameras), Remove the 5G mmWave antenna: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logic Board Removal (Rear Cameras), Remove the 5G mmWave antenna: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingers to remove the mmWave antenna.
    • During reassembly, make sure the mmWave antenna goes under the front facing camera cable.
  23. Logic Board Removal (Rear Cameras), Disconnect the interconnect cables: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Disconnect the interconnect cables: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Disconnect the interconnect cables: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the press connector near the bottom left corner of the logic board.
    • Use the point of a spudger to disconnect the press connector just to the right of the previous one.
  24. Logic Board Removal (Rear Cameras): crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logic Board Removal (Rear Cameras): crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of an opening pick under the top edge of the press connector near the bottom right corner of the logic board.
    • Be very careful not to damage the small, surface-mounted components to the right of the connector.
    • Use the pick to pry up and disconnect the press connector.
  25. Logic Board Removal (Rear Cameras), Remove the antenna board cover: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logic Board Removal (Rear Cameras), Remove the antenna board cover: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP screwdriver to remove the 5.4 mm‑long screw securing the antenna cover in the top left corner.
  26. Logic Board Removal (Rear Cameras): crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logic Board Removal (Rear Cameras): crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingers to remove the cover.
  27. Logic Board Removal (Rear Cameras), Disconnect the antenna board: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Disconnect the antenna board: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Disconnect the antenna board: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the autofocus sensor press connector from the top left corner.
    • Carefully move the cable out of the way so you can access the metal antenna connector underneath.
  28. Logic Board Removal (Rear Cameras): crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logic Board Removal (Rear Cameras): crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide one arm of your angled tweezers under the metal neck of the antenna connector and lift straight up to disconnect it.
    • To reconnect, hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
  29. Logic Board Removal (Rear Cameras), Remove the logic board: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Remove the logic board: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Remove the logic board: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up the top edge of the logic board until you can grip it with your fingers.
    • Grip the right side of the logic board and carefully remove it, being careful that no cables get snagged (one front facing camera cable and four cables along the bottom edge).
    • During reassembly, hold the front facing camera cable out of the way and lower the logic board into place, making sure the four cables along the bottom edge don't get trapped underneath.
  30. Logic Board Removal (Rear Cameras), Reassembly information: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Reassembly information: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logic Board Removal (Rear Cameras), Reassembly information: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • During reassembly:
    • Check the condition of the logic board thermal pad—it will either be on the bottom of the logic board or on the frame.
    • If the pad is undamaged, skip the rest of this step.
    • If the pad is damaged, use the flat end of a spudger to scrape it up and remove it.
    • Use isopropyl alcohol (greater than 90%) and a microfiber cloth to remove all thermal pad residue from the frame and bottom of the logic board.
    • Apply a new thermal pad to its spot on the frame.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
119.160 crwdns2915208:0crwdne2915208:0
crwdns2935297:0838crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.729crwdne2935297:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 47
