Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement
  1. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement, Disconnect the spark plug: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement, Disconnect the spark plug: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, make sure the engine is switched off and cool to the touch.
    • Pull the spark plug connector straight off of the spark plug.
  2. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement, Remove the air filter cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the bolt securing the air filter cover
  3. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the air filter cover 90° and lift it straight up to remove it.
  4. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement, Remove the throttle cable: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #2 screwdriver to loosen the screw securing the throttle cable clamp.
  5. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of needle nose pliers to lift the throttle cable out of its slot on the throttle body.
  6. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the throttle cable out of its clamp.
  7. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of flush cutters to cut through the zip tie securing the throttle cable to the auger and remove it.
    • Repeat this step for all seven zip ties along the throttle cable.
  8. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a flathead screwdriver to loosen the throttle cable end clamp.
  9. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the end of throttle cable from the clamp.
  10. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the red screw clamping the throttle cable in the holder on the handle.
  11. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the throttle cable from its holder on the handle.
  12. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the throttle cable out of the braided wiring sleeve.
  13. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement, Remove the throttle lever: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement, Remove the throttle lever: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement, Remove the throttle lever: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The throttle lever is held in place by a flared rivet. You will need to replace this rivet with a new one, and re-flare it, during reassembly.
    • Use needle nose pliers to bend the flared end of the rivet inward to straighten it.
  14. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pin punch and a hammer to tap the rivet out of the handle.
  15. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use needle nose pliers to unhook the throttle lever spring from the throttle lever.
  16. Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Little Beaver Augers MDL5HD 2017 Throttle Lever and Cable Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the throttle lever.
    • Remove the throttle lever spring.
Adam O'Camb
crwdns2935283:004/11/15crwdne2935283:0
214,541 crwdns2915208:0crwdne2915208:0
crwdns2935297:0416crwdne2935297:0
crwdns2942667:0crwdne2942667:0 886
