Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement
  1. Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement, Disconnect the spark plug: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement, Disconnect the spark plug: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, make sure the engine is switched off and cool to the touch.
    • Pull the spark plug connector straight off of the spark plug.
  2. Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement, Remove the clutch bracket clamp: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 5/16 inch socket to remove the two nuts securing the clutch bracket clamp.
    • You may need another 5/16 inch wrench to hold the bolt from underneath while you loosen the nut.
  3. Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the clutch bracket clamp.
  4. Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement, Remove the clutch drum: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 5/32 inch hex wrench to loosen the two set screws on the clutch drum.
  5. Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the clutch drum straight off of the clutch rotor assembly.
  6. Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a flathead screwdriver or small pry bar to pry the clutch drum off of the flexible shaft.
    • Slide the clutch drum off of the flexible shaft and remove it.
    • During reassembly, apply anti-seize lubricant to the interface between the clutch drum and flexible shaft.
    • The clutch drum can be replaced as part of the clutch assembly replacement.
    • The replacement clutch drum should come with a new pilot bearing installed. If it doesn't, you may need to install a new pilot bearing.
  7. Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement, Remove the clutch rotor assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement, Remove the clutch rotor assembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a long-handle 5/32 inch hex wrench to loosen the two set screws on the clutch rotor assembly.
    • The first photo shows the set screws on the replacement part for reference. Loosen the screws on the installed part, not the replacement part.
    • The screws are positioned behind the clutch rotor and won't be easy to access. Use a long-handle hex wrench as shown in the second photo.
  8. Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Little Beaver Augers MDL5HD 2017 Clutch Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the clutch rotor assembly off of the engine drive shaft.
    • The clutch rotor assembly can be replaced as part of the clutch assembly replacement.
    • During reassembly, make sure the clutch rotor assembly key is inserted correctly into its slot before reassembly.
    • During reassembly, apply anti-seize lubricant to the interface between the clutch rotor and engine drive shaft.
Adam O'Camb
crwdns2935283:004/11/15crwdne2935283:0
212,431 crwdns2915208:0crwdne2915208:0
crwdns2935297:0416crwdne2935297:0
crwdns2942667:0crwdne2942667:0 894
