Lite-On iHAS324 Eject Button and Power LED Light Replacement
  1. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Chassis: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lite-On iHAS324 Eject Button and Power LED Light Replacement, Chassis: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a paper clip into a small hole on the right side of the faceplate bellow the disc tray.
    • There may be resistance, do not be afraid to use force.
    • The tray should then pop open.
    • Pull out the tray so that it is fully extended.
  2. Lite-On iHAS324 Eject Button and Power LED Light Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lite-On iHAS324 Eject Button and Power LED Light Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lite-On iHAS324 Eject Button and Power LED Light Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to push the three tabs located on the right, left, and bottom side of the outer chassis to loosen the faceplate off.
  3. Lite-On iHAS324 Eject Button and Power LED Light Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the faceplate off the chassis.
    • Do NOT pull the faceplate all the way off the disc tray, because doing so can cause damage to the faceplate.
  4. Lite-On iHAS324 Eject Button and Power LED Light Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips Head #2 screwdriver, unscrew the two 8.5 mm screws located on the bottom back of the chassis.
  5. Lite-On iHAS324 Eject Button and Power LED Light Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom plate by lifting it off the device.
  6. Lite-On iHAS324 Eject Button and Power LED Light Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device over.
    • Remove the top plate by pulling the sides and lifting the plate off.
  7. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Disc Tray: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lite-On iHAS324 Eject Button and Power LED Light Replacement, Disc Tray: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the left tab in and slide the tray out on the left side.
    • Pull the gray plastic casing on the right side away from the tray.
    • Slide the right side of the tray out.
  8. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Disc Tray Belt: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take tweezers and remove the black tray belt from the gears carefully.
  9. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Eject Button and Power LED Light: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device over.
  10. Lite-On iHAS324 Eject Button and Power LED Light Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to pull all three tabs, lifting up the circuit board as you go.
  11. Lite-On iHAS324 Eject Button and Power LED Light Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the circuit board out of the plastic casing.
  12. Lite-On iHAS324 Eject Button and Power LED Light Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a solder wick, unsolder either the eject button or Power LED Light. Soldering Guide
    • Then, using a solder iron, replace them.
Kayla Culpepper
crwdns2935283:003/22/15crwdne2935283:0
702 crwdns2915208:0crwdne2915208:0
Baylor, Team 5-9, Williams Spring 2015 crwdns2935289:0Baylor, Team 5-9, Williams Spring 2015crwdne2935289:0
BU-WILLIAMS-S15S5G9
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 862
