Insert a paper clip into a small hole on the right side of the faceplate bellow the disc tray.
The tray should then pop open.
Pull out the tray so that it is fully extended.
Use a plastic opening tool to push the three tabs located on the right, left, and bottom side of the outer chassis to loosen the faceplate off.
Using the Phillips Head #2 screwdriver, unscrew the two 8.5 mm screws located on the bottom back of the chassis.
Remove the bottom plate by lifting it off the device.
Turn the device over.
Remove the top plate by pulling the sides and lifting the plate off.
Push the left tab in and slide the tray out on the left side.
Pull the gray plastic casing on the right side away from the tray.
Slide the right side of the tray out.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Take tweezers and remove the black tray belt from the gears carefully.
Use a plastic opening tool to pull all three tabs, lifting up the circuit board as you go.
Carefully lift the circuit board out of the plastic casing.
Using a solder wick, unsolder either the eject button or Power LED Light. Soldering Guide
Then, using a solder iron, replace them.
