Has your disco ball stopped rotating and turned into a weird, multi-colored lamp? Use this guide to avoid the party-foul and get that ball spinning!
Turn the device over so that the base is on top.
Peel off the piece of metal that is glued to hold the two halves of the base together.
Unscrew the four 10mm Phillips head screws on the bottom of the device.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to crush the sides of the wirenuts.
Pull all of the wires out of the wirenuts.
Separate the wires that belong to the motor.
Remove the motor.
To reassemble your device, follow these instructions in reverse order, starting from step five.
Where can you find a replacement motor?
I can't find one either!!!!
