If you just can't find out what is wrong with your disco ball, you will probably need to open it to troubleshoot it. This guide will walk you through the steps to do that.
Turn the device over so that the base is on top.
Peel off the piece of metal that is glued to hold the two halves of the base together.
Unscrew the four 10mm Phillips head screws on the bottom of the device.
crwdns2935219:0crwdne2935219:0
