Linksys WRT54GS v2 Power Connector Replacement
    1. Linksys WRT54GS v2 Power Connector Replacement, Front Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the router over so that all four of its feet are facing upwards.
    2. Linksys WRT54GS v2 Power Connector Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the rubber inserts inside the the two purple feet located on the router's front case.
      • This may be a challenge, so try the following two methods:
      • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
      • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
    3. Linksys WRT54GS v2 Power Connector Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
    4. Linksys WRT54GS v2 Power Connector Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
    1. Linksys WRT54GS v2 Power Connector Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the board unit out and up.
    2. Linksys WRT54GS v2 Power Connector Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the circuit board over and use a Phillips #2 Screwdriver to remove the 6.9mm screw holding the board to the back case.
      • Slide the back cover out and away from the circuit board.
    1. Linksys WRT54GS v2 Power Connector Replacement, Power Connector: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the circuit board over.
      • Identify the solder connections on the board, marked in red.
    2. Linksys WRT54GS v2 Power Connector Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Desolder the connection by following iFixit's guide to repairing soldered connections: How To Solder and Desolder Connections.
      • Remove the Power Connector from the board.
      • Insert the replacement power port and resolder the connectors.
Alex Do
crwdns2935283:010/12/11crwdne2935283:0
51 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-4, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 3-4, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S3G4
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 101
crwdns2942667:0crwdne2942667:0 2,362
