Linksys EA9200 Antenna Port Replacement
  1. Linksys EA9200 Antenna Port  Replacement, Linksys EA9200 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Linksys EA9200 Antenna Port  Replacement, Linksys EA9200 Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the sticker on the bottom.
    • Remove the two screws holding the bottom plate in place. Use Phillips screwdriver tip #1 , the screw head-size is 5mm.
  2. Linksys EA9200 Antenna Port  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Linksys EA9200 Antenna Port  Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back sticker that has all the labels.
    • There are two screws to remove. They are 6mm in diameter, use phillips screw tip #1.
  3. Linksys EA9200 Antenna Port  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Linksys EA9200 Antenna Port  Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Linksys EA9200 Antenna Port  Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Depress the 12 clips along the edge into the router. Use the nylon spudger as using a metal object could cause damage.
  4. Linksys EA9200 Antenna Port  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Linksys EA9200 Antenna Port  Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Linksys EA9200 Antenna Port  Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once you have one side open, keep a spudger wedged between both sides. This will help keep it open in case it tries to snap back together.
    • These clips are tough and may need some additional force.
  5. Linksys EA9200 Antenna Port  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Linksys EA9200 Antenna Port  Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Linksys EA9200 Antenna Port  Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the board and pull down, away from the antennas.
  6. Linksys EA9200 Antenna Port  Replacement, Antenna Port: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Linksys EA9200 Antenna Port  Replacement, Antenna Port: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The antenna ports are connected to the board with a wire that has a "snap" connector.
  7. Linksys EA9200 Antenna Port  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Linksys EA9200 Antenna Port  Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder the four pins of the antenna port.
    • Do not place the soldering iron on the wrong terminals as this can cause the device to no longer to function.
    • How To Solder and Desolder Connections is iFixit's official guide on how to use a soldering iron
    • You will need a soldering iron that is capable of reaching temperatures greater than 300 degrees Fahrenheit.
    • Temperature of the component will be very hot when desoldered, take precaution when handling.
  8. Linksys EA9200 Antenna Port  Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the solder is melted, quickly pull broken antenna port.
Shane Davis
crwdns2935283:010/05/16crwdne2935283:0
374 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 9-1, Lacy Fall 2016 crwdns2935289:0USF Tampa, Team 9-1, Lacy Fall 2016crwdne2935289:0
USFT-LACY-F16S9G1
crwdns2942667:0crwdne2942667:0 939
