Linksys EA6900 Router Reset Button Replacement
  1. Linksys EA6900 Router Reset Button Replacement, Linksys EA6900 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Linksys EA6900 Router Reset Button Replacement, Linksys EA6900 Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Linksys EA6900 Router Reset Button Replacement, Linksys EA6900 Disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the antennas by unscrewing them from the base.
    • Flip over the device and locate the four rubber feet on the bottom.
    • Remove the rubber feet with tweezers
  2. Linksys EA6900 Router Reset Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
  3. Linksys EA6900 Router Reset Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a blue plastic opening tool to remove the top cover.
    • Move the blue plastic opening tool gently underneath the top cover from side to side.
  4. Linksys EA6900 Router Reset Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Linksys EA6900 Router Reset Button Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Linksys EA6900 Router Reset Button Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the motherboard and remove it from the case
    • Put the motherboard over a (preferably white) surface.
  5. Linksys EA6900 Router Reset Button Replacement, Router Reset Button: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Linksys EA6900 Router Reset Button Replacement, Router Reset Button: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure to correctly identify the red router reset button.
    • Locate the four solder points on the other side of the motherboard.
  6. Linksys EA6900 Router Reset Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Linksys EA6900 Router Reset Button Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be careful when working with the hot soldering iron! Make sure the router motherboard is safely resting on a level and sturdy surface.
    • Carefully apply the soldering iron to the four solders. Avoid touching the motherboard with the soldering iron, this could damage the circuits.
    • Use a spudger to gently pry and remove the reset button once the solder has melted.
Rick Hsu
crwdns2935283:009/15/16crwdne2935283:0
355 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 11-1, Blackwell Fall 2016 crwdns2935289:0USF Tampa, Team 11-1, Blackwell Fall 2016crwdne2935289:0
USFT-BLACKWELL-F16S11G1
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 2,007
