Lighting: Replacing Light Emitting Diode
    1. Lighting: Replacing Light Emitting Diode, Light Emitting Diode: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a plastic opening tool, remove the base of the Light Angel.
      • Insert the plastic opening tool between the base and the LED housing and pull outwards on the handle.
    2. Lighting: Replacing Light Emitting Diode: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a Phillips head jeweler's screwdriver, remove the screw on the battery housing.
      • To remove the screw, turn counterclockwise.
      • Remember to put all the screws you take out somewhere safe so you can find them when it's time to reassemble the light.
    3. Lighting: Replacing Light Emitting Diode: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove and set aside the (4) AA batteries in the battery housing.
    4. Lighting: Replacing Light Emitting Diode: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a Phillips head jeweler's screwdriver, remove the (6) screws holding the LED housing together.
      • To remove the screws, turn counterclockwise.
    5. Lighting: Replacing Light Emitting Diode: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert the plastic opening tool into the crease on the side of the LED housing to separate it from the rest of the device.
    6. Lighting: Replacing Light Emitting Diode: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the faulty light emitting diode on the back of the circuit board.
      • Using a soldering iron and desoldering braid, unsolder the connection on the light emitting diode.
      • Do not allow the soldering iron to come in contact with other components on the circuit board.
      • For detailed instructions on how to solder go to How To Solder and Desolder Connections
    7. Lighting: Replacing Light Emitting Diode: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert the new light emitting diode through the two holes left from removing the old one.
      • Note: the picture is not of the Light Angel circuit board. It is a general example of inserting a light emitting diode on a circuit board. Photo Credit: How To Solder and Desolder Connections
    8. Lighting: Replacing Light Emitting Diode: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using solder and a soldering iron, solder the new LED to the circuit board.
      • Keep your solder joints separate to avoid short circuiting the circuit board.
Matthew Corigliano
crwdns2935283:002/10/16crwdne2935283:0
155 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 8-6, Mcmichael Spring 2016 crwdns2935289:0Colorado Springs, Team 8-6, Mcmichael Spring 2016crwdne2935289:0
UCCS-MCMICHAEL-S16S8G6
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 61
crwdns2936753:030crwdne2936753:0 136
crwdns2942667:0crwdne2942667:0 6,897
