LifePrint 3x4.5 Charging Port Replacement
  1. LifePrint 3x4.5 Charging Port Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place one hand on the top cover and one hand on the bottom portion of the LifePrint.
    • While having the LP logo on the printer facing away from you, push the top cover away from you until it can't be slid away any further.
    • Pull the cover with the LP logo up to separate it from the rest of the printer.
  2. LifePrint 3x4.5 Charging Port Replacement, Inner Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the four 15 mm screws connecting both sections of the device.
    • Use an opening tool to remove the inner cover from the printer.
  3. LifePrint 3x4.5 Charging Port Replacement, Charging Port: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five Phillips #0 screws from the outer edge of the motherboard indicated by the copper color surrounding the screws' housing.
  4. LifePrint 3x4.5 Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a soldering iron to heat up the soldering joints surrounding the port that connects the device to the circuit board.
    • After the solder is heated up use the de-soldering wick to absorb the solder holding the socket to the circuit board .
    • After the solder is removed use the tweezers to remove the port from the circuit board.
Jacqueline Broderick
crwdns2935283:011/05/19crwdne2935283:0
341 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G2, Barthe Fall 2019 crwdns2935289:0UMass Dartmouth, Team S1-G2, Barthe Fall 2019crwdne2935289:0
UMASSD-BARTHE-F19S1G2
crwdns2942667:0crwdne2942667:0 515
