LifePrint 3x4.5 Battery Replacement
  1. LifePrint 3x4.5 Battery Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place one hand on the top cover and one hand on the bottom portion of the LifePrint.
    • While having the LP logo on the printer facing away from you, push the top cover away from you until it can't be slid away any further.
    • Pull the cover with the LP logo up to separate it from the rest of the printer.
    Possibly have a closed picture of the printer with an arrow of which way to push the top cover. Then have this picture second.
    Ed LaLumiere - crwdns2934203:0crwdne2934203:0
  2. LifePrint 3x4.5 Battery Replacement, Inner Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the four 15 mm screws connecting both sections of the device.
    • Use an opening tool to remove the inner cover from the printer.
  3. LifePrint 3x4.5 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three 4mm Phillips #0 screws connecting the metal shield covering the battery.
    • Slide out the white power connector with two red wires, two black wires, and one yellow wire from the terminal connected to the circuit board.
    • Apply pressure gently and slowly from underneath the battery from the plastic.
    Identify which screws are being taken out and where the wire connectors are using ifixits guidelines (markup colors in order for each step (ROYGIBV) ).
  4. LifePrint 3x4.5 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the printer.
    I feel like your pictures are out of order with your descriptions. because step 2 needs a picture of the removal of the connector and step 4 has the battery out but step 3’s description is about putting the battery back in.
Jacqueline Broderick
crwdns2935283:011/05/19crwdne2935283:0
341 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G2, Barthe Fall 2019 crwdns2935289:0UMass Dartmouth, Team S1-G2, Barthe Fall 2019crwdne2935289:0
UMASSD-BARTHE-F19S1G2
Où trouver la batterie ? Quelles caractéristiques ?
Baphi - crwdns2934203:0crwdne2934203:0
C'est parfait mais la batterie EVE P0867 7.4V 900mAh est introuvable... Avez vous un lien ?
Merci
Laurent Villiger - crwdns2934203:0crwdne2934203:0
Thank you for instructions. Do you know where to buy the 7.4V 900mAh battery? I can't seem to find one.....thanks!
Julie - crwdns2934203:0crwdne2934203:0
I am looking for a battery for my “Lifeprint LP002-1 printer” it has in it a lithium Ion 1000mah 7.4v battery .
I have been unable to find an exact replacement , do you know if there is an equivalent battery available ?.
Tina page - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,603
