LifePrint 3x4.5 Battery Replacement
  1. LifePrint 3x4.5 Battery Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place one hand on the top cover and one hand on the bottom portion of the LifePrint.
    • While having the LP logo on the printer facing away from you, push the top cover away from you until it can't be slid away any further.
    • Pull the cover with the LP logo up to separate it from the rest of the printer.
  2. LifePrint 3x4.5 Battery Replacement, Inner Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the four 15 mm screws connecting both sections of the device.
    • Use an opening tool to remove the inner cover from the printer.
  3. LifePrint 3x4.5 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three 4mm Phillips #0 screws connecting the metal shield covering the battery.
    • Slide out the white power connector with two red wires, two black wires, and one yellow wire from the terminal connected to the circuit board.
    • Apply pressure gently and slowly from underneath the battery from the plastic.
  4. LifePrint 3x4.5 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the printer.
Jacqueline Broderick
crwdns2935283:011/05/19crwdne2935283:0
341 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G2, Barthe Fall 2019 crwdns2935289:0UMass Dartmouth, Team S1-G2, Barthe Fall 2019crwdne2935289:0
UMASSD-BARTHE-F19S1G2
Où trouver la batterie ? Quelles caractéristiques ?
Baphi - crwdns2934203:0crwdne2934203:0
C'est parfait mais la batterie EVE P0867 7.4V 900mAh est introuvable... Avez vous un lien ?
Merci
Laurent Villiger - crwdns2934203:0crwdne2934203:0
Thank you for instructions. Do you know where to buy the 7.4V 900mAh battery? I can't seem to find one.....thanks!
Julie - crwdns2934203:0crwdne2934203:0
I am looking for a battery for my “Lifeprint LP002-1 printer” it has in it a lithium Ion 1000mah 7.4v battery .
I have been unable to find an exact replacement , do you know if there is an equivalent battery available ?.
Tina page - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 60
crwdns2942667:0crwdne2942667:0 1,803
