This guide is for first time builders or people that bought prebuilt computers in a Lian Li PC-011 case. This guide will walk you through how to install or replace a 3.5 hard drive in the case. It is not a very difficult task and it should only take you 30 minutes to complete.
Power off the system using the button on the back of the computer.
Remove the power cord from the computer.
Remove two thumb screws from the back of the case.
Slide the top panel backwards.
Remove the remainder of the panels by pulling upwards on them.
Remove the two 3 mm Phillips #2 screws from the wire cover.
Unplug the two cables from the hard drive.
Push together the bottom and top tabs and pull the hard drive tray out of the case.
Remove four #2 Phillips screws from the hard drive case in a cross pattern.
Replace the old hard drive with the new hard drive.
Il ni à pas de languette chez moi et sa veut pas sortir
