Lexmark T650 Fuser Roller Replacement
    • A damaged pressure roller leads to paper jams.
    • A damaged non-stick coating on the heated roller causes dark marks and double images. Toner that sticks to the non stick coating on the heated roller makes an after-image or marks 94mm (3.7 inches) below the original dark print.
  1. Lexmark T650 Fuser Roller Replacement, Remove front cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove these two 6mm Philips #2 screws then remove the front cover
  2. Lexmark T650 Fuser Roller Replacement, Remove top cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lexmark T650 Fuser Roller Replacement, Remove top cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove these two 6mm #2 screws from the two ends of the heating element and carefully withdraw the glass heating element.
    • The glass heating element is shown in the second picture.
    • Remove these two 6mm #2 screws attaching the top cover.
    • Remove this screw attaching the red power cable.
    • Unplug the pair of yellow wires and unhook them from the hooks tucking them in place.
    • The top cover can now be removed.
  3. Lexmark T650 Fuser Roller Replacement, Release the springs: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lexmark T650 Fuser Roller Replacement, Release the springs: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a wedge under each of the two spring support arms to lift the two springs.
    • The wedges should remain in place while the fuser unit is being stored. Otherwise the pressure from top roller will make a permanent indentation in the soft pressure roller.
    • The second picture shows a suitable wedge. This example was made from a toothbrush handle.
  4. Lexmark T650 Fuser Roller Replacement, Remove paper guide: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lexmark T650 Fuser Roller Replacement, Remove paper guide: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • gently bend this paper guide to remove it.
  5. Lexmark T650 Fuser Roller Replacement, Remove top roller: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lexmark T650 Fuser Roller Replacement, Remove top roller: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lexmark T650 Fuser Roller Replacement, Remove top roller: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use circlip pliers to remove the circlip attaching the cogwheel to the top roller.
    • Slide this metal catch upwards to release the bearing from its holder. Remove the bearing.
    • The top roller can now be removed.
    • The red pressure roller is now visible with its bearings resting in the holder at each end.
  6. Lexmark T650 Fuser Roller Replacement, Remove the pressure roller: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lexmark T650 Fuser Roller Replacement, Remove the pressure roller: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The pressure roller can now be lifted out.
David42
crwdns2935283:002/11/18crwdne2935283:0
1 468 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 1,515
